Home Racing World • View topic - Lola T160 build 3 - re-chassied with piano wire
For 1/32nd Scale Models
Re: Lola T160 build 3 - re-chassied with piano wire
Postby chrisguyw » Wed Apr 26, 2017 8:58 pm
chrisguyw
Postby VTECFOUR » Thu Apr 27, 2017 3:49 pm
@ Radarek - about 3/32" clearance from track surface.
Ready now for a test run against versions 1 and 2 with my adjust-o-wheelbase square brass tube/piano wire construction and Devised Designs slimline motor pod.
Same motor, a Scalextric 20K red slimline, with the identical 3:1 gear ratio installed.
Body's lower on the chassis than before.
Overall weight's now 78g from 91g. Feels planted and driveable on my little test track.
More telling once I get a few comparison laps on Luf's Big Targa, Chris's Killarney and Roger's Maple Ridge tracks this weekend.
VTECFOUR
Postby JT Previa » Thu Apr 27, 2017 8:42 pm
Dan, Looks great as usual. Always nice to see your clean work.
(I have one of those Strombecker (?) bodies too. Great detail. Started to modify it - if cutting it into four sections still qualifies as modification - but it is now entombed in Tupperware, awaiting recombination.)
JT
JT Previa
Postby VTECFOUR » Fri Apr 28, 2017 12:12 am
Hi JT,
The Lola's my re-pop of the Maxi Models T160 body. I hate grinding resin so I've gotten quite good at slosh casting light weight bodies. Sometimes I'm thin in a few spots but that's easy to reinforce with fast setting two-part epoxy. I'd rather add than subtract.
Good to see you're doing some slot car stuff.
VTECFOUR
Return to 1/32 Showcase
