Lego slot car parts.
Postby BARC 1 » Mon Apr 03, 2017 6:49 pm
I have been using Lego for quite some time in modeling projects from 1/16 scale tanks to 1/43 slot cars. The other day I just set out to find what I might be able to use directly for slot cars
I just received these lego wheels. They are 14.7 mm across with the rubber on. The wheels just pop off and a 3/32 ID brass tube fits firm in the opening allowing you to make hubs so you can use them with 3/32 axles. $1.49 for 8 wheels with tires. These have rims that almost look like VW rims. I bought other sets as well that have four spoke wheels. Good thing is they are Lego so you know they probably are making thousands of them. So if you want scale wheels for your cars, look at what Lego might have to offer
I also bought a 4X2 window frame that works as a perfect motor mount for my BARC sized can motors.
Re: Lego slot car parts.
Postby frank9129 » Mon Apr 03, 2017 7:52 pm
I went to the Lego store the other day. I didn't see those wheels. I just wanted to get some 1x1s and 4x1s. Can't do it. I had to buy 50 pieces for $8.50.
Where did you score the wheels, on line?
frank9129
Postby BARC 1 » Mon Apr 03, 2017 8:29 pm
eBay has online retailers who sell just specific blocks. Just start down the rabbit hole, and you will find what you need.
