Home Racing World • View topic - Chassis for Carrera Stang
Postby HomeRacingWorld » Fri Mar 17, 2017 9:19 am
Re: Chassis for Carrera Stang
Postby dw5555 » Fri Mar 17, 2017 9:30 am
Now that seems like a worthwhile investment. Stock the rear of the Carrera mustangs sit about inch off the ground. Might even be competitive with some of the other brands.
Dave
dw5555
Postby Changing-Gearz » Fri Mar 17, 2017 9:53 am
Harry - you don't let anything slip by!
Inline only for this one. I tried for months to find a solution with a SW pod - but it kept looking like the original Carrera chassis.... I'm happy with the look now.
Here is a shot of the stance:
Changing-Gearz
Postby HomeRacingWorld » Fri Mar 17, 2017 10:39 am
Uh huh, that looks tasty:) I really like these bodies and want them on the track for more combat. I did make a brass chassis once, but I am keen to try this.
Postby 4424ever » Fri Mar 17, 2017 10:45 am
I was figuring on brass for these as well I don't recall an article on yours Harry did you do one?
4424ever
Postby HomeRacingWorld » Fri Mar 17, 2017 11:21 am
I did one awhile back.
Postby Ky.Slot Racer » Fri Mar 17, 2017 12:34 pm
CG,
Any interior rub with this option?
Ky.Slot Racer
HRW Master Modeler
Postby DaveKennedy » Fri Mar 17, 2017 2:15 pm
I'm VERY happy to see this... and mine is on the way from Shapeways!
Postby 4424ever » Fri Mar 17, 2017 4:50 pm
Sooooo that would be a stinker stand then eh. Sorry I couldn't resist :D
4424ever
Postby waaytoomuchintothis » Fri Mar 17, 2017 4:56 pm
I'm with Dave. I went out and counted the cars and ordered 3 today.
Postby Changing-Gearz » Fri Mar 17, 2017 7:44 pm
Changing-Gearz
Postby frank9129 » Fri Mar 17, 2017 7:48 pm
There are many Artin-stein chassis out there. It is one of the most changeable. Has anyone tried to copy it?
frank9129
Postby BRS Hobbies » Fri Mar 17, 2017 8:03 pm
Is it possible to use the stock Carrera Mustang rear axle and motor with a compatible inline motor pod? I like to keep my cars as stock as possible but like the lower stance of your chassis.
Best regards,
Brian
BRS Hobbies
Postby Changing-Gearz » Fri Mar 17, 2017 8:38 pm
Carrera axles are smaller - and knurled. They will not work with the slot.it bushings.
You can probably get there with some work on the wheels and gear - but the axle difference is around .25mm - so one wrong move and your reaching for super glue
Inline pods are easy to find - most people switched them out on the Slot.it group c cars to a side-winder pod. I have 4-5 hanging around for example.
The Carrera motor is an FC130 can - it will drop right in. I think Slot.it flipped the motor around in the pod at some point (or maybe thats just the SW pod....(?)) - you just have to make sure the motor shaft is pointed the right way!
Changing-Gearz
Postby HRWJim » Fri Mar 17, 2017 8:42 pm
I'll be picking up a couple of these. I hope they do the Vette too. Not that the chassis was as bad but I'm sure it would run better.
Return to Slot Car News!
