Home Racing World • View topic - 69 Camaro Trans Am Car
For 1/43rd Scale Models
Postby BARC 1 » Thu Mar 09, 2017 8:25 pm
I built a GCC sidewinder Twincan (2 Minebea S Class) in 143 for a 69 Trans Am Camaro. Painted in BARC Livery.
A Resin cast pulled off of a diecast with rear fender flares added. The car is sitting on BARC Bite urethane tires
Chassis is using piano wire to remove any flex on the gift card with good results
Re: 69 Camaro Trans Am Car
Postby clivearmstrong74 » Thu Mar 09, 2017 10:41 pm
Very nice, Dan!!! Looking good[CHEQUERED FLAG][CHEQUERED FLAG][HUNDRED POINTS SYMBOL]
Clive
clivearmstrong74
Postby Z-carfan » Thu Mar 09, 2017 11:05 pm
BARC, You are out of this world! Amazing work with your 1/43 cars. Simply outstanding!!!
Postby pfuetze » Fri Mar 10, 2017 12:03 am
Dan, the BARC livery is awesome on the Camaro!
Very nice paint and decals, i like the "twincan" over the wide wheel arches! great!
very nice work on the chassis as well!
the details of your interior are great, too, roll cage, the window fence, driver figure - very nice!
great job!
Postby taskak » Fri Mar 10, 2017 4:32 am
taskak
Postby glasshorsevh » Fri Mar 10, 2017 5:42 am
Yet again, amazing stuff from BARC Racing.... I feel like I'm just repeating what everyone else is saying... Hmm, are twocans better than parrots?
glasshorsevh
Postby TuscoTodd » Fri Mar 10, 2017 6:10 am
Great looking build and love the livery and added touches like "Twin Can" over the rear flares!
Good stuff!!!
:text-bravo:
Postby BARC 1 » Fri Mar 10, 2017 8:06 am
Thank you for the comments
I made the driver netting by cutting strips of masking tape and then making the weave pattern. It was then painted white and is nice and flexible to make the installation easy.
I have to say I personally liked the way the BARC Trans Am markings came out on the Camaro. The fantasy livery looks the part
I have not been able to roll this car yet. The low COG twincans and the piano wire cross members that transfer lift from the rear wheel to the opposite front wheel seems to work. The result is a car that drivers very predictably, with the rear end letting go giving you a warning without a wreck. The trouble with the cross members is that they prevent an interior tub, and I have to go back to a tray. The piano wire was used to stiffen the giftcard chassis, and maybe it is just the new rigidity that works. The thought that as the rear wheel begins to lift, this upward force is applied to the piano wire cross member and is applied as a downward force to the opposite front wheel sounds cool though.
I think I will take this cross member idea into my next 132 build and see if it works there as well. This is half the fun of all these scratchbuilds. I don't think any two are exactly the same as I try new ideas.
Postby Dodgefarmer » Fri Mar 10, 2017 10:55 am
Nicely done Dan. Gotta like a predictable drive too. :text-bravo:
Randy
Dodgefarmer
Return to 1/43rd Scale Showcase
Users browsing this forum: No registered users and 39 guests
