Kurtis Midget Kit In
Re: Kurtis Midget Kit In
Postby HomeRacingWorld » Sun Feb 03, 2013 7:33 pm
Well, got a little further this afternoon.
Hood and nose in place. Had to do some good wet sanding to clean up the fit, they had plenty of overlap. Not perfect, but clean enough I suppose.
Used my Dremel and cutting disc to get rid of the belly pan. then used 1/4 sanding barrel to clean it up and finally sandpaper by hand.
The strip fits fine. That is if I use it. Still in the chassis planning stages.
Now I am out of parts that I planned to use. That's ok because sometimes that is a good thing for me. I get "ansy" and start hacking too much and stuff does not go like I want it. Having to step back and actually think about things always helps :lol:
Postby Dangermouse » Mon Feb 04, 2013 7:22 am
Chap over on sci been sharing his brass chassis building another chap posted some picks of his midget build
http://www.slotcarillustrated.com/porta ... 369&page=5
Link should take you to the page post #63
David
Dangermouse
Postby HomeRacingWorld » Mon Feb 04, 2013 7:51 am
Thanks, he is doing good work there!
Postby HomeRacingWorld » Mon Feb 04, 2013 9:29 am
Expert? No, Locoracer Tom won't be here until Saturday:)
If it is my shoulder you refer to, please wear eye protection and a blast shield. I just soldered (attempted) some stuff and it is unfit to post on this family-friendly forum. :doh:
Postby HomeRacingWorld » Mon Feb 04, 2013 10:52 am
Not a design most use, just came up with something that would fit and work. So far so good.
Shaft is not perfectly lined with the axle, but VERY close and should be ok. Testing will tell the tale.
Postby HomeRacingWorld » Mon Feb 04, 2013 11:04 am
If you need some sleeve tubing, I have plenty.
Postby HomeRacingWorld » Mon Feb 04, 2013 11:46 am
I have no clue. I think the SL-1 might be better. These little suckers would be fast enough I thinks.
I have motors for you either way anyhow, so your covered.
Postby HomeRacingWorld » Mon Feb 04, 2013 11:53 am
Yep, that's the plan. I have them too if you need them.
Postby HomeRacingWorld » Mon Feb 04, 2013 11:57 am
It is good to have a plan.
Unlike the way things are done here at Waterhead Engineering.
Tom is coming Saturday and you know he will build a better one and make it look twice as easy.
Postby HomeRacingWorld » Mon Feb 04, 2013 1:46 pm
Well, she is a roller :)
Set the width by what the kit had. Figured that is close enough :)
Now to work out a guide.
Postby DAVE » Mon Feb 04, 2013 2:19 pm
This might be too late for you, but the slimlines fit better turned 90 degrees so that the flats are
on the sides. You still will have enough ground clearance.
DAVE
Postby HomeRacingWorld » Mon Feb 04, 2013 2:26 pm
Oh oh, somebody who knows what they are doing! :)
Too late, but it fits ok.
Thanks Dave, I appreciate your help here. You know I am going to booger this up sooner or later.
Postby HomeRacingWorld » Mon Feb 04, 2013 3:34 pm
Just went with a straight tube mount for the guide. I could have made a separate tongue at the right angles, just decided this was just as good.
Used 3/16" brass tube which sleeves it nice and snug.
Not the traditional route, but it will work. No slop to speak of and strong.
Postby HomeRacingWorld » Mon Feb 04, 2013 8:39 pm
Well, have a runner now. Motor is just glued in and just working out any issues.
9/27 Slot.it gears. Slot.it wood guide. SCC Wheels for testing, might go to 15x7....not sure yet.
Fun though! Still plenty to do, but she is trackin' now.
Postby MoparGreg » Mon Feb 04, 2013 10:21 pm
Harry that is seriously unreal. Great job. Its amasing what you have done in the short amount of time. You have made a hard buildup due to the size of these midgets look easy. Now stop slacking off & finish it already :)
MoparGreg
