Re: what´s on your bench right now?
Postby pfuetze » Wed Oct 26, 2016 1:00 pm
​Image​
Image​
Image​
building the roll cage - not my favourite work, i have to say ...
new Mini chassis with ball bearings and new type of tyres with rounded sidewall :D
Postby BARC 1 » Wed Oct 26, 2016 8:43 pm
That looks like it will be very fast. Those tires look very familiar to me. I may have used the same master to cast mine. I am sending along 10 pairs for prizes in your Proxy.
Postby pfuetze » Thu Oct 27, 2016 12:22 am
the masters for these tires have been printed in frosted ultra detail material by shapeways. CarGo casted these tires for me (and i think will make them available for everyone who is asking). I like the look way better the old ones which where casted from Marchon Jeep H0 wheels with flat sidewalls.
The Mini is not that fast, i´m still searching for the best motor/gearing combination.
The ball bearings and the 2.38mm axles hopefully will make changing gears a little easier. Still, i will have to drill out H0 gears, due to size, the Mini wheels are 11mm
Postby strangebrew » Thu Oct 27, 2016 10:00 am
strangebrew
Postby BARC 1 » Thu Oct 27, 2016 1:16 pm
I really like those modifed stockers, and as you know I hope to do one soon.
I would also like to try one in 1/43 scale
Postby pfuetze » Sat Nov 05, 2016 1:02 pm
Postby BARC 1 » Sun Nov 06, 2016 10:44 am
You should frame that Peter. The doodlings of Davinci :D
Postby pfuetze » Mon Nov 07, 2016 12:06 pm
Guides for the Dune Buggies ...
Postby LloydL » Mon Nov 07, 2016 3:08 pm
You had me worried for a minute when I saw the magnets Peter, then I remembered that the Desmo has copper tape!
Regards, Lloyd.
LloydL
Postby pfuetze » Tue Nov 08, 2016 12:34 am
no worries, Lloyd, i´m going to pull them and use them on the fridge ;)
Postby taskak » Tue Nov 15, 2016 4:00 am
taskak
Postby walker » Tue Nov 15, 2016 4:37 am
Is the bentley plastic or metal ? What firm ?
Roland
My actual projects -
cast some cars, convert / build a Camaro and finished the track painting.
Roland
walker
Postby taskak » Tue Nov 15, 2016 4:43 am
taskak
Postby walker » Tue Nov 15, 2016 5:46 am
Thank you.
So I will copy my Minichamps one. I want to build the complete line - Aston, Audi R8, Mercedes CLK and CLR, Nissan, Saleen, Venturi, Lister, Marcos etc.etc. The only one I am sadly not able to find is the Mosler.
Mostly I am looking forward to building the Panoz Spyder. It had been a lot of fun in 32nd scale to build a front driven chassis, and now in 43rd scale it will be a thrill. Fortunately I have really small motors.
Roland
walker
Postby BARC 1 » Wed Nov 16, 2016 7:58 pm
Roland you have been busy. The track looks nice and I like that you left an oval option.
Aki. How are the tires working out for you?
I have been building a couple of 132 proxy racers, and built my first brass chassis in over a decade. I may do a change up on a chassis and try submitting a brass 143 one. Maybe change out the Carrera GT3 Porsche.
Well done guys
