Home Racing World • View topic - Small animated track scene
Plastic Or Wood
All Things Track Building!
Postby btaylor » Sun Oct 30, 2016 9:38 am
Re: Small animated track scene
Postby TuscoTodd » Sun Oct 30, 2016 9:54 am
Get this error...
Sorry, this content isn't available right now
The link you followed may have expired, or the page may only be visible to an audience you're not in.
May need to post it on youtube in order for us to see it?
Postby btaylor » Sun Oct 30, 2016 9:59 am
try it now Todd. I had it locked I guess?
Postby TuscoTodd » Sun Oct 30, 2016 10:25 am
Very cool sir! :D
Postby Gameover » Sun Oct 30, 2016 11:13 am
Way cool. Glad to see you stuff again brother. Hope all is well!
Postby HomeRacingWorld » Sun Oct 30, 2016 11:25 am
I want some. When can you come by?
Postby dreinecke » Sun Oct 30, 2016 2:46 pm
That is awesome!
Postby dge467 » Sun Oct 30, 2016 7:47 pm
That is cool!
Postby CJR » Mon Oct 31, 2016 3:23 am
Quite awesome!
CJR
Postby btaylor » Mon Oct 31, 2016 7:33 am
Thanks for all the positive feedback on this! It was/is a simple project. I used a gear reduction motor from a dollar store animated Christmas ornament. Removed the linkage, and put a three inch round plate on the motor shaft. Bent up two sides to activate the rod on the Strombecker flagman. Drilled a hole through the table and glued the guy down. simple and effective. It really adds some realism to that area of the track. just a little movement here and there really makes the track come alive.
Postby Nor Cal Mike » Mon Oct 31, 2016 8:01 am
You are out doing yourself Bob! Well done sir.
Nor Cal Mike
Postby TsgtRet » Mon Oct 31, 2016 11:19 am
Outstanding, Bob (as usual). :banana-dance:
I'm still busy working on the static part of my track, let alone animation (but this does feed the imagination)!
Postby Broman62 » Mon Oct 31, 2016 4:53 pm
Good stuff BT...also like the "GULF" sign flashing in background!!!
Postby ourwayband » Mon Oct 31, 2016 6:32 pm
That is one of the coolest deals on a slot car layout I've seen!
