55 Chevy - first ever oval racer build
Re: 55 Chevy - first ever oval racer build
Postby dreinecke » Mon Aug 15, 2016 5:57 pm
Looking good!
Postby TuscoTodd » Tue Aug 16, 2016 6:57 am
Too cool that the wires fit in the trans tunnel!
:handgestures-thumbup:
Postby VTECFOUR » Thu Oct 13, 2016 12:39 pm
Still slow going, but some progress. Filled in the body corners with styrene and putty for a smoother look.
Finally decided on a finish with Tamiya TS42 Light Gun Metal to contrast against the stock red interior.
VTECFOUR
Postby HomeRacingWorld » Thu Oct 13, 2016 10:57 pm
Looking great from here. Inspiring build.
Postby Wobble » Fri Oct 14, 2016 12:00 am
Even in primer that is looking really smooth
Wobble
Postby VTECFOUR » Sat Oct 29, 2016 12:11 pm
This build's taken forever but it's pretty much there.
Finished with Tamiya Gun Metal spray and paint detailed the trim, interior and wheel inserts in Tamiya flat aluminum and Lin Gray.
Need to find misplaced head and tail lights and install mesh grille. Will finish off with a Luf's lady driver figure.
VTECFOUR
Postby bdsharp » Sat Oct 29, 2016 3:49 pm
That came out great! Will it be making a Showdown appearance?
bdsharp
Postby Wobble » Sat Oct 29, 2016 5:35 pm
Love it and the inserts really set it off
Wobble
Postby Broman62 » Sat Oct 29, 2016 5:43 pm
Awesome build VT!! Yep... the inserts and lowering make it look so cool!!
Postby dreinecke » Sat Oct 29, 2016 10:02 pm
That is just drop-dead sexy!
Postby lotuscortina » Sat Oct 29, 2016 11:59 pm
Nice build, Too nice to race hard ;) , I think I had better look after it for you.... :) :)
Nige.
lotuscortina
Postby Ky.Slot Racer » Sun Oct 30, 2016 4:18 pm
Looking good Dan, great job on smoothing out the curves too, can`t go wrong with the tri-5s. And I`m a big fan of those kit wheels for inserts, those in the know,,,know these very closely resemble the popular "weld wheels" racing wheels from the 70s. I actually made a rubber mold of these so I could use them at will. Also the chassis is a winner, I`ve found with all the chassis I have put together, the solid design seems perform better more often than a more elaborate build. One more note I notice is the rear slot.it wheel lends itself to resemble the floater hubs the way it protrudes past the wheel center. SUPER BUILD MAN ! BIG KUDOS
Ky.Slot Racer
HRW Master Modeler
Postby Dundee Denny » Sun Oct 30, 2016 6:34 pm
Appreciate all the narrative on this build!!
Thinking about getting my feet wet with a brass build and your pictorial was very informative.
Then if a get mine to look as striking as yours..............
Dundee Denny
Dundee Denny
Postby chappy » Sun Oct 30, 2016 8:11 pm
Hahaha, well done Dan, i am laughing since i just painted my Panamericana 57 Ford today.
Tamiya Aluminum, lol great minds my friend great minds.
B
