I give you the Razor Pro, the best truer for the serious racer.
First off lets just make this clear, the Pro will ONLY TRUE ALLUMINUM SET SCREW WHEELS
You can NOT TRUE AXLE SET'S ON THE PRO
The Pro comes ready to true 1\24 or 1\32 The wheels are held by a Nitride harden ejector pin, the ejector pin spins in sealed flanged roller bearings held in the axle block
The sanding block comes with 2 grits 400-1500
I have one ready to sell and 4 more waiting on pins
This is a limited time only, first come first served, you can only get the Pro from me here on HRW
Price is $185.00 Shipped to all 50 States
Price is a little more than your standard Razor but only for the added Ejector pin and Sealed Flange Roller Bearings
THIS TRUER IS ONLY FOR SET SCREW WHEELS
