Home Racing World • View topic - Building Prairie Winds Test Track
Got Wood?
Your ROUTED TRACK Home!
Re: Building Prairie Winds Test Track
Postby DrumPhil » Mon May 30, 2016 10:22 pm
Lots of other jobs demanded time today, but did get the track screwed in place and spackled. Also glued down a remnant of MDF under the overhang in one spot where space for tail sliding was a little tight.
Ready to cut spots for wiring and then paint the roadway.
DrumPhil
Postby SLOTTING SINCE 1963 » Tue May 31, 2016 6:38 am
Looking good ......... keep going.
Painted and copper tape.....soon!!!!!
Richard
SLOTTING SINCE 1963
Postby DrumPhil » Wed Jun 01, 2016 8:35 pm
Put down the first layer of concrete, er, paint on the roadway tonight. It's actually a paint/primer combination. How many paint layers do you experts recommend on the road surface?
DrumPhil
Postby slothead » Wed Jun 01, 2016 8:46 pm
I only did one coat of paint over the primer and regret it now - my Bondo repairs show through. Couldn't see them or that I didn't get them sanded smooth till the paint fully dried. Now I have to pretend not to notice.
Slothead
slothead
The Doctor is IN!
Postby dreinecke » Wed Jun 01, 2016 9:09 pm
I did two if it needed it. The track looks great!
Postby buspor63 » Wed Jun 01, 2016 9:56 pm
buspor63
Postby Z-carfan » Wed Jun 01, 2016 10:14 pm
I'd do two coast minimum. My test track isn't much smaller, and it holds up well unless you use it as a table. :)
Postby 2FER SLOTS » Thu Jun 02, 2016 5:09 am
I concur, 2 be fine.
This really makes it look like a roadway,will be fun to watch you paint in the details.
Remind me to go look for some blue foam chunks I think I saved. :think:
2FER SLOTS
Postby DrumPhil » Sat Jun 04, 2016 7:32 pm
Taping and wiring are done. It's alive!
Derek's homemade taping tool worked great - no breaks, and both taps worked the first time. :P
DrumPhil
Postby 2FER SLOTS » Sun Jun 05, 2016 7:05 am
Fun driving slot cars isn't it. :lol:
Looks real good ! Would you recommend building wood tracks to your friends ?
2FER SLOTS
Postby DrumPhil » Sun Jun 05, 2016 10:50 am
DrumPhil
Postby slothead » Sun Jun 05, 2016 7:04 pm
For a small footprint, that's a great track. I've been following this since you started posting about building a track, and even copied the original plan for this track on graph paper to see if I might use it too. In my version the left hand turn is a sweeper with a somewhat consistent radius, though I imaged cars going clockwise so it opens up a bit going into the back straight.
Is that a lap counting and timing gantry on the front straight? If so I hope you'll post lap times for your cars. If I go ahead with an indoor-outdoor 4' x 8' oval it will be one lane too and the fun will come from recording lap times for similar cars then simulating multi-car races on the computer. There are many ways for solo racing to be a lot of fun.
Slothead
slothead
The Doctor is IN!
Postby HomeRacingWorld » Mon Jun 06, 2016 6:10 am
Just a great effort.
You will certainly have many hours of fun on it.
Postby 2FER SLOTS » Mon Jun 06, 2016 6:31 pm
2FER SLOTS
Postby TuscoTodd » Tue Jun 07, 2016 1:52 pm
That just looks like a good time!
Bravo sir!
Return to The Lumber Yard
