Home Racing World • View topic - Goofy power question
Plastic Or Wood
All Things Track Building!
Postby DrumPhil » Fri Apr 08, 2016 9:23 am
Still planning my first wood track, and I realized that any way to cut costs would help me get it built sooner. Then I had a goofy idea. Tell me if this will work.
I found an old laptop power supply: says 19V, 3.42A. So I'm wondering, can I use that for a free power supply and run it through a DC voltage controller (to reduce power) and reversing switch? I found a $12 unit (see photo) that should give me both voltage control and reversing switch. Will that work?
Also, do I need an inline fuse, like maybe 3A, or am I okay without it since the PS only puts out 3.4A?
(If it matters, I'm planning on using a budget PM controller and only RTR to very mildly tuned cars.)
Thanks as always.
DrumPhil
Re: Goofy power question
Postby RazorJon » Fri Apr 08, 2016 11:23 am
If you put 1 on each lane but 3 Amps for a 4 lane track wont be enough, I had a 2.5 Amp on a 3 lane and when I put my new PS on it was a big difference and I run tame motors, I think my 0-20 V 10 amp was under 60 bucks shipped
How clean is that PS? if its not filtered it will let AC leak in and that's hard on motors
Postby DrumPhil » Fri Apr 08, 2016 12:57 pm
DrumPhil
Postby HomeRacingWorld » Fri Apr 08, 2016 1:22 pm
Postby 2FER SLOTS » Fri Apr 08, 2016 2:45 pm
I'll give you a walwart if you want it.
2FER SLOTS
Postby RichD » Sat Apr 09, 2016 6:34 am
You can use that motor speed control to reduce the voltage, but the output would not be pure DC. If it was me I would use a variable voltage regulator like this one: https://drive.google.com/open?id=0BzLR4 ... A3NjdjNTZh .
Postby jcis4me » Wed May 18, 2016 6:12 am
For Power I'm using a 12 volt lawn tractor battery, less than 40 bucks at wally world. or even cheaper use the battery from your car, just run a couple of wires to the car and 12 volt power. Just saying to save costs...
jcis4me
Postby HomeRacingWorld » Wed May 18, 2016 6:28 am
The Tenma supply is about 26 bucks shipped. Cheaper than a battery, less space, no fuss.
Plus it's adjustable. At 2 Amps it's perfect for a 1 lane track.
Postby mattb » Wed May 18, 2016 6:40 am
I used a 1960's Sears 10 amp battery charger for 30 years. It probably had ac leakage, but I never had any motor problems in all those years. If you can find a cheap regulator for it you would be set. For your one lane track the power supply you have should be fine with the regulator you have shown.
mattb
Postby DrumPhil » Wed May 18, 2016 9:08 pm
Thanks for all the suggestions. I love ended up going with an inexpensive 2-amp unit. I picked this one because it has continously variable voltage, instead of steps. It was about the same price as the one Harry recommended.
DrumPhil
Postby HomeRacingWorld » Wed May 18, 2016 9:10 pm
Nice choice. There are so many choices today, it's easy to find a decent source.
