HRW Can-Am proxy!
Re: HRW Can-Am proxy!
Postby Retro Racer 44 » Mon May 16, 2016 11:56 pm
If you have Goop, it can be peeled away if necessary and comes off cleanly.
Have fun with them, eh?
Retro Racer 44
Postby Audi1 » Tue May 17, 2016 4:12 am
I sent Matt an email this morning, with chappy's message attached and a request that he get in touch with Bob. I do think at this point that he would say glue it back on.
Postby Changing-Gearz » Tue May 17, 2016 6:03 am
Hey!
I was a bit of a zombie yesterday from travelling so a little late to respond....
So - I'm fine with any repair and glue.... I shattered that section with my dremel before the car left and tried to fix it up enough for the journey - I was trying to get the weight out of the rear.... Didn't work obviously.... Made a note to myself not to use the big router bit on bodies anymore.....
I can skip this round if the car is a holdup.... If it can be fixed - I very much appreciate the help!
I do have a new body that it an improved design - if there is no objection - I'd like to mail it - or replace it when the cars get to Allan's (If he is the next round(?). Basically it has better weight and the front mounting has a better fit... I should be far enough out of contention that I only want to go for looks now.... I'm ok with a penalty to replace it as well?
Anyone object to a body replacement?
Changing-Gearz
Postby Audi1 » Tue May 17, 2016 6:34 am
Not me - I'd like to see the Shadow run up to it's full potential. Let's get that body swapped out.
Postby Z-carfan » Tue May 17, 2016 9:25 am
That works for me, let's keep her running.
Postby chappy » Tue May 17, 2016 9:58 am
No way Matt ,you wont miss this.
That Shadow will be on the grid and in the heat of battle.
Easy fix.
Postby Aloha » Tue May 17, 2016 10:56 am
Change body if you need ok with me. I watched the nascar race at Dover this past weekend and they did everything but pull the whole skin off those cars.
Besides we need to have $ in the field
Aloha
Dale
Aloha
Postby Retro Racer 44 » Tue May 17, 2016 11:04 am
Bob, since your time clock is running down, why not do a quick fix right away and run the round.
Matt can send the new body here and I will swap them when the cars arrive.
It will be a couple of weeks before I can run the race here anyway, as I will be out of town next week. I share a mailbox with my daughter and son-in-law anyway so they will pick up the mail when it arrives.
Cheers,
Keith
Retro Racer 44
Postby chappy » Tue May 17, 2016 12:19 pm
Thats a great idea Keith.
I will do the repair for this round and mail you the cars .
I am gone all of June so you making the swap works out fine.
Postby Retro Racer 44 » Tue May 17, 2016 12:38 pm
Sounds good. I will PM my address to Matt.
Keith
Retro Racer 44
Postby chappy » Tue May 17, 2016 1:29 pm
Thanks Keith.
Qually tonight with Pics.
Stay tuned to, this station .
Re: HRW Can-Am proxy! Lake on the Mountain
Postby chappy » Wed May 18, 2016 5:30 pm
Just a quick note to let you know the Lake on the Mountain leg of the Proxy has been run.
Last night I finished the repairs and tested the cars on track. But it was too late to do the qually , so the boys and I gathered this morning, and conducted qually and then the heats were ran after lunch.
Finally finished at 5pm ET So now its time for some results and pictures
Qualification
P Class
Car # time.
60. - 7.337
48. - 7.454
66. - 7.498
65 - 7.768
2c. - 7.885
917. - 8.090
16. - 8.218
20. - 8.244
5. - 8.283
$$$ - 8.449
0. - 8.450
19. - 8.465
9. - 8.792
11. - 9.286
12. - 10.803
Class B
52. - 7.624
59. - 7.663
65b. - 7.880
41. - 8.143
some very close times.
Race results in next post
Postby chappy » Wed May 18, 2016 7:40 pm
Well here is what you have been waiting for , the results and the pictures, triumph and tragedy
Class P
Car # Laps Total. Fast Lap
60. - - - 45.2. - - 7.228
48. - --44.8 - - - 7.352
65. - - - 42.7 - - - - 7.520
66. - - -42.0- - -- - 7.484
0. - - -- 40.4-- --- -7.789
917. - -- -40.3- -- -- 8.011
16. -- --40.1. - --- - 8.050
$$$ - -- - 39.9. - - -7.777
20. - - - 39.4. - - - -8.218
19. - -- -- 38.2 - -- - 8.630
2c. - - - - 37.7. - - -- 7.575
5. - -- - 35.4. - - -- 8.419
9. - -- - -34.9. - - - 8.710. Very bad rear hop on right turns likely tire edge.
11. -- - - -34.0. - -- -9.555. Stock tires were not up, to the job , needs urethanes
12. -- -- - 30.8. - - -10.648 as above no traction due to stock tires
Class B
52. -- -- - 42.6. - - 7.609
59. - - - 42.4. - - 7.491
65b. - -- -41.6. - - - 7.616
41. - - - -39.3. - - 8.276
Concours was Tough Overall , but the 52 in B Class was the choice of the members .
Pics to follow
Congrats to the Podiumites , I Believe Chris W, Audi1, and Retro in Class P
KY racer , Audi1, Retro in Class B.
Thanks for the opportunity to drive your cars, our priveledge, Thanks to Kev, Mike and Steve for the good drives and the help getting her all done
Postby Brumos RSR » Wed May 18, 2016 7:52 pm
Congratulations to the podiumites!!! Chris, Audi1 ^2, Retro ^2 and Ky Racer and thanks Sir Chappy and your team for the quick run
Brumos RSR
Postby Rleog » Wed May 18, 2016 7:54 pm
Thanks for wringing them out, Chappy. Looks like I'm going to have a tough time getting a podium finish in this series. Quick car but too unstable in the corners.
It's a pleasure to be among such a fine field of cars.
Rleog
