Hi Bob,
I keep it simple and just slosh cast.
Getting the master ready for the mold is really the bulk of the work and it's key to quality re-pops.
Once I clean up the mold of flash (Smooth On Mold Max 30 silicone)that can block the flow of the resin, I'm ready to go with my simple molding process and set up.
Materials:
resin - Smooth On Smooth-Cast 321 in off white color. Easier to see body features and imperfections than plain white.
kitchen scale - to measure weight of mixing batches of part A and part B. Purchased at Lee Valley
silicone gloves - to keep hands clean
small chop stick - to stir part A and B and to push out air bubbles and force resin in small crevices and crannies. The one piece ones that snap into a pair from fast food Asian take-outs
small paper or plastic mixing cup - for mixing resin
paper towel - eight small squares cut from one towel to clean up dripping material from containers and wiping excess resin
newsprint - to cover table top from inevitable spills
I like making my bodies with as little excess resin as possible, so mine come out pretty thin and light.
My latest, a Lola T160, took 11g of part A and 11g of part B with very few heavy areas. If thin in some spots, I just reinforce with two part epoxy after.
You'll notice a standby mold, usually wheel inserts that I do first then the body.
As mentioned, the resin does cure in about eight minutes, so I spill the resin in the mold to get coverage in the top of the body, moving it back and forth and then spend the rest of the time sloshing the resin along the sides, front and rear. All along I'm poking the resin into the voids and crevices with the chop stick.
You'll know when you've got to move really fast as the transparent mix quickly becomes opaque. If you think you've got too much in some spots just remove the excess with the chopstick, wiping it on to the paper towels.
As it comes to the end of solidifying, I turn the mold upside down for the excess to run down the sides, front and back and accumulating. I then remove any excess with the stick.
I try to leave it alone and within 20 minutes, it's already solid. I usually wait a couple of hours and pop it out, ready to do the next one.
If you like doing tires, you'll really like molding bodies.
Have fun!
P.S. My casting and molding materials are Smooth On products purchased locally and online from Sculpture Supply, a Toronto area Smooth On dealer. I just use the starter kits.
