by Cosmic Bilby » Fri Jan 25, 2013 5:12 am
Look I don't want to labour a point but... (I will :) )
Mag or no mag it doesn't make a scrap of difference.
We are talking about two rear wheels of the same diameter (well they should be, the only exception could be oval where the inner tracking wheel is a smaller diameter sometimes).
These two wheels go around a circuit in tandem, sometimes on the inside "track" of a corner, sometimes on the outside. A rear "differential" that slips will let one wheel turn more the other less.
It assists handling (and can also be used as a torque limiting device as we have seen earlier in the thread), bottom line it assists handling the same as those beautiful Independent front ends that Slot.it sell as an aftermarket part.
Until we can embrace proven concepts such as this slot cars and the competitive side of the hobby in particular won't move forward, its as simple as that.
At the end of the day I think opinions are like Arseholes, everyone has one, I'll be sticking with mine, it has served me well through the years :)
