Lola T160 build 2 - Finished!
For 1/32nd Scale Models
Postby VTECFOUR » Thu Apr 21, 2016 12:51 pm
The first build worked out so well, performance and modeling-wise, that I'm starting on a team car. This one will have a similar chassis and the body will be painted in dark metallic blue like the Gurney car.
Stay tuned.
VTECFOUR
Re: Lola T160 build 2
Postby HomeRacingWorld » Thu Apr 21, 2016 12:52 pm
Nice choice. Will follow :)
Postby VTECFOUR » Thu Apr 21, 2016 5:08 pm
Hi guys,
Yep, one of my body cast re-pops.
Brass cut for my adjust-o-wheelbase chassis to accommodate a Devised Designs FF050 super slimline motor pod.
main rails - 3/32" square
front axle support - 3/32" square
front axle tube - 1/8" square
front axle assembly sliders - 1/16" square
guide tongue, front and rear rail braces - .064 strip
guide tube - 5/32" round
Sure helps to have done one already and use as reference.
May solder up tonight.
VTECFOUR
Postby chrisguyw » Thu Apr 21, 2016 5:59 pm
Looking good Dan!!!....... :text-bravo: .
I was just looking at the chassis shots of your previous T160 build, and if you don't mind, there are a couple of things that might be worth considering on this build. On your first T160 build, it would appear that there is room to extend the guide post tube further ahead (lengthening the distance between the rear axle and guide tube). As this is a relatively small car (length) it would likely be highly advantageous to maximize this dimension....this will result a smoother handling car.
And, have you considered using piano wire (.055 or.063) for your main chassis rails??......from a performance and durability perspective, the wire is so much better than square brass tube, and if well cleaned, just as easy to solder.
Chris Walker
chrisguyw
Postby bill from nh » Thu Apr 21, 2016 7:49 pm
The 1/24 retro racers use quite a variation of main rails. Some use 3/32" square main rails filled with soldered-in .055 or .063 piano wire. .078 piano wire (2mm) could be used, as could various combinations of different diameter brass rods & piano wire.
bill from nh
Postby VTECFOUR » Sat Apr 23, 2016 5:37 pm
Took the suggestions and made a new guide tongue to lengthen the post and used piano wire for the sliders instead of brass.
Should have it running tomorrow.
VTECFOUR
Postby VTECFOUR » Sat Apr 23, 2016 9:50 pm
Drivetrain's in and chassis runs just fine.
Trying out the new universal Sloting Plus guide that allows customized trimming.
Will be interesting to compare with build 1's performance.
Body mocked on and looks good too.
Will get some primer on tomorrow.
VTECFOUR
Postby VTECFOUR » Sun Apr 24, 2016 6:57 pm
Body's mounted.
Stance is good.
Now primer can go on.
VTECFOUR
Postby Retro Racer 44 » Sun Apr 24, 2016 10:02 pm
Lookin good, Dan. Are you putting a wing on this one?
Cheers,
Keith
Retro Racer 44
Postby HomeRacingWorld » Mon Apr 25, 2016 5:55 am
Very nice. Curious on your thoughts on the guide. Just used it myself and it's really a nice one.
Postby VTECFOUR » Mon Apr 25, 2016 5:35 pm
@ Retro Racer - going wingless again
@ Home Racing World - like this guide in general. Pros: good value, wire ferrules included, lots of blade to custom profile. Cons: Wide and flat screw included but small Philips screwdriver required, spacers not provided unlike Scale Auto universal ones.
Some build progress.
Primer's on.
Before paint I had a chance to run on Luf's Big Targa. Ran a 7.65 second fastest lap, significantly faster than Build 1's 8.09. I suspect the new rear rubber had something to do with this. Other differences were the wider rear track, longer rear axle to guide post length and piano wire use.
In any case, a very pleasant surprise.
VTECFOUR
Postby dreinecke » Mon Apr 25, 2016 10:38 pm
Great looking build as usual Dan!
Postby VTECFOUR » Tue Apr 26, 2016 2:07 pm
Done!
Sprayed multiple coats of Tamiya grey primer, Blue TS15, Mica Blue TS64, Racing Blue TS51 and accented details in black, grey and silver
Had trouble with the side roundel numbers being brittle.
Team Lola looks good and performs well.
Taking a break now.
VTECFOUR
Re: Lola T160 build 2 - Finished!
Postby HomeRacingWorld » Tue Apr 26, 2016 2:18 pm
Well done! Congrats on a fine build.
Postby Audi1 » Tue Apr 26, 2016 2:27 pm
Very, very nice build!
Return to 1/32 Showcase
