Changing the track up.
Postby MichiganCur » Sat Jan 16, 2016 10:33 pm
Decided to change up the track today. Still wanting to do a routed track, but till then occasionally hacking up a piece will have to suffice.
Any thoughts on design appreciated. Image
One of the said hacked up pieces
MichiganCur
Re: Changing the track up.
Postby pfuetze » Sun Jan 17, 2016 2:27 am
I like the layout!
Postby ourwayband » Sun Jan 17, 2016 6:16 am
Looks like fun..The cool thing about plastic is what you are doing..One can change,adjust and just totally redo their layout is a short amount of time..
Postby MichiganCur » Sun Jan 17, 2016 7:47 am
The nice thing about the table is its built for my kids to stand and look down into it. For me at 6 ft there's only a car length of blind spot before coming back under the bridge on the back left loop. Originally I wanted two bridges but I don't have enough of the plastic supports. So until I get around and cut some lumber for supports it works out. Putting the r2 at that corner also helps as its a little bit more forgiving than the r1 if the little ones come in to hot.
The straight I had a bad rail on, it would bounce the cars out and deslot them so it made for a good trial piece. If I mussed it up there was no real loss haha. But now I'm glad I did it, I want to get a few more corners and try making some odd angles to change up the corners even more. :-)
MichiganCur
Postby MichiganCur » Sun Jan 17, 2016 6:03 pm
Well found a few more bits of track in a box in my workshop. And made a few trial wedges out of some scrap 1x4. I like the adjustment and it's kinda fun to see if I can jump from the drop and reslot before the corner hahaha Image
MichiganCur
Postby MichiganCur » Sat Mar 19, 2016 3:24 pm
Well the 180 on the first loop was just too much, if you were on the inside Lane pretty much just gunned it coming out of turn 3 and hoped that you made it through the corner before the outside Lane made more than 3/4ths a lap. I tried power jumps adding in straights, nothing really seemed to equal the two lanes out so.. Changed it up again.
MichiganCur
Postby ourwayband » Sun Mar 20, 2016 6:11 am
Looks good!
Postby cyclone60 » Tue Mar 22, 2016 10:36 am
Nice layout :music-rockout:
Have fun with it ! :auto-driving: :auto-checkeredflag: :auto-driving:
cyclone60
