A Gift Card chassis with a sidewinder was used on this to allow room inside for some interior detailing and Driver figure. I tried something different with this one and built a motor pod. Motor and rear axle bearing block are one piece. This keeps the relationship between the spur gear and pinion solid and Chassis flex has no effect on this.
This is a resin cast body with Vacuum formed glass.
Aluminum rims with photo etch inserts were used
Peter sent me a guide, so I used it on this build.
Decals from Pattos.
