Bentley tire size
Forum rules
Bentley tire size
Postby loosewheel » Thu Mar 17, 2016 3:10 pm
What size do the Carrera Bentley Speed Six take, can't seem to find in on the chart?
loosewheel
Re: Bentley tire size
Postby HomeRacingWorld » Thu Mar 17, 2016 4:05 pm
Do you have a way to measure the wheel? Measure the inner rib width and diameter please?
Postby loosewheel » Fri Mar 18, 2016 8:39 am
The rib is 6 mm and the diameter is 15.6 mm. I was thinking 22116 xxxd?
loosewheel
Postby SlotCarCorner » Fri Mar 18, 2016 9:40 am
What is the diameter of the stock tire when mounted on the stock wheel? Also, overall width of the tire when mounted on the wheel?
:text-thankyouyellow:
SlotCarCorner
Postby loosewheel » Fri Mar 18, 2016 10:45 am
Don't have the stock tires, bought it as a basket case for the body. Hence the confusion, does anyone out there know the size of the stock tires?
loosewheel
Postby paul gage » Fri Mar 18, 2016 11:00 am
last one I fit took PGT-21126XD,
and PGT-21126XXD would also fit with a small concave dip in the center...
paul gage
Postby Rleog » Fri Mar 18, 2016 11:03 am
For the Bentley EXP Speed 8:
Front diameter 21 mm, width 10.5 mm
Rear diameter. 22.3 mm, width 11.2 mm
Width of the contact patch on each tire is slightly less.
The rear wheel has a diameter of 18.2 mm, so the Speed 6 and Speed 8 must be different cars. Sorry, I thought that you were referring to the Speed 8.
Rleog
Postby loosewheel » Fri Mar 18, 2016 11:26 am
Thanks very much! This forum is the greatest!
loosewheel
Return to The Tire Shop
