Toyota S800 Spyder build
For 1/32nd Scale Models
Re: Toyota S800 Spyder build
Postby VTECFOUR » Mon Feb 08, 2016 5:23 pm
Body mock fitted.
Stance works for me.
VTECFOUR
Postby Beast Lee » Mon Feb 08, 2016 6:48 pm
Wow...!!! :music-rockout:
Beast Lee
Postby VTECFOUR » Mon Feb 08, 2016 7:58 pm
My usual adjustable wheelbase chassis for small car's rolling and running...
...built with:
- Devised Designs Super Slim FF050 motor pod held in with 2mm screws
- perimeter chassis of 3/32" and 1/16" square brass tube and .062" brass strips, 1/8" square for front axle holder, and 1/8" tube for guide holder
- Scale Auto universal guide
- Slot It tinned braid and silicone guide wire
- SCX Fiat Abarth Campagnolo plastic rims and tires for the front and inserts from turned down rims
- Slot It F1 rims for the rear with trued down Fly March F1 urethane re-pops
- Scalextric FF050 20K red motor
- Slot It 9t pinion for 1.5mm shafts
- SCX Pro 27t crown
Chassis runs well but will feel more planted with .062 side pans soldered on.
Body's just mock fitted but am shooting for this stance when mounting posts are in place.
VTECFOUR
Postby DRW21 » Tue Feb 09, 2016 3:24 pm
Very simple and very tidy, well done.
Should be a great runner too.
DRW21
Postby VTECFOUR » Wed Feb 10, 2016 1:39 am
These small car builds are greatly facilitated with ready made motor pods that eliminate fussing with motor and axle shaft squareness and level planes. The Devised Designs Super Slim pod works well for me as the BWA motor bracket is no longer available. Their front axle/guide stamped carrier is missed as well. Those plumber chassis by Florida Slotter, Chrisguyw and DRW21 are so gorgeous that I'm encouraged to give it a try.
In the meantime, good progress on my simple chassis with side pans and side exhaust detail soldered in.
Body's mounted too but I might try to lower it at the rear so there's reduced gap between the body and pipes.
On to the body work with paint and detailing.
VTECFOUR
Postby VTECFOUR » Thu Feb 11, 2016 3:00 pm
I did manage to drop the rear with rear mounting post trimming and wheel arch filing.
The gaps between the side exhaust pipes and the body have been closed.
Might seem a bit anal, but it would have bugged me.
Time for some primer.
VTECFOUR
Postby VTECFOUR » Sat Feb 13, 2016 2:16 pm
Still deciding on final color, so primer`s on hold.
In the meantime, gave it a serious run on Luf`s Targa Burnaby, a good test for any car.
As hoped, it goes as good as the Coupe getting into the 7`s easily. That`ll keep up with the stock Slot It cars, my goal for these little car builds. Added a 9g strip of .064 lead for a total weight of 81g. Car`s now more planted and driveable at the limit.
Back to modelling. What color?
VTECFOUR
Postby VTECFOUR » Tue Feb 16, 2016 7:27 pm
Tamiya Fine White primer's on.
Going with a yellow/green finish after seeing a Racer Silverline treatment of a Toyota 2000 GT. Will leave the brass side pipes alone and paint detail the wheels in gold.
VTECFOUR
Postby VTECFOUR » Thu Feb 18, 2016 3:30 pm
This build's final color choice has been particularly wishy washy for me so I've finally settled on red using Tamiya's TS8 Italian Red spray. I'm starting with their pink primer as they suggest for a red final coat.
Never used it before so I'm curious to see how the red tone will come out compared to light grey primer.
VTECFOUR
Postby VTECFOUR » Fri Feb 19, 2016 1:45 am
Pretty much done. The Tamiya Italian Red spray covered really well on top of the pink primer. It's much brighter than the pics show.
After paint, the rest came pretty quickly.
- applied assorted decals
- Installed driver figure and fairing headrest
- paint detailed body and wheels
I particularly like the exhaust side pipes, so I give thanks to the fella who gave me the idea in the first place, Marty Stanley, RIP.
VTECFOUR
Postby CrockettNZ » Fri Feb 19, 2016 2:32 am
that is a lovely looking build :text-bravo:
CrockettNZ
Postby Brumos RSR » Sat Apr 02, 2016 5:38 pm
Don't know how I missed this but that is an incredible little car you have there,'both fast and nimble
Brumos RSR
Postby Audi1 » Sat Apr 02, 2016 5:42 pm
That came out looking very nice! I agree, the pipes really set if off; particularly with the neat and simple decaling.
Postby Wobble » Sat Apr 02, 2016 11:48 pm
Yowsers, that is too cool.
Wobble
Postby CrockettNZ » Sun Apr 03, 2016 2:49 am
I like that a lot
well done :text-bravo:
CrockettNZ
Return to 1/32 Showcase
