Home Racing World • View topic - Razor Tip How to get both tires to touch
Postby RazorJon » Sun Jan 03, 2016 7:31 am
Over the years I have gotten e-mails about Tires wanting to touch one side before the other when truing :?:
This is an easy fix, on the Tire Razor
Here you see more sanding dust on the left
Why does it do this?
It has to do with sloppy axle\bushings, tires being different sizes, or even just the bushing riding up a tiny amount
how to fix it? Very simple
look at the bottom of your machine
You want to loosen the side that touches first, this raises that side of your axle block
Small Turns, it wont take much
As you can see, both sides are sanding the same now
Very simple to do, easy fix :text-bravo:
Thx for watching, see you next time
Re: Razor Tip How to get both tires to touch
Postby Broman62 » Sun Jan 03, 2016 2:36 pm
Postby RazorJon » Sun Jan 03, 2016 2:45 pm
The Wheel Buddy has a special end on it for truing stock plastic ribbed wheels
Lets you sand all those little spots, has saved me from buying new wheels when just a little truing was needed
lets face it round is round be it made of aluminum or plastic
Postby Broman62 » Sun Jan 03, 2016 2:55 pm
Postby Austin » Sun Jan 03, 2016 4:04 pm
I love the Wheel Buddy for plastic wheels for the Paul Gage Tires. The money I save not buying so many aluminum wheels will pay for the Razor and make life much easier.
Austin
Postby RazorJon » Mon Jan 04, 2016 9:42 am
Guess next weeks tip will be the Wheel Buddy :music-rockout:
Postby Broman62 » Mon Jan 04, 2016 7:49 pm
Postby RazorJon » Thu Nov 15, 2018 12:15 pm
bump this up front
If you need extra help
scrjon160@aol.com text me your name and number and good time to call I will call you and help
Return to SlotCar ToolTime
