Home Racing World • View topic - Finally!
Finally!
Got Wood?
Your ROUTED TRACK Home!
Re: Finally!
Postby Dogsbody » Mon Dec 21, 2015 1:00 pm
So, all the track pieces are here and I'm ready to join the track together (braid, etc is on it's way). Whats the best way to do it and keep the pieces straight and more importantly, smooth where the joints are?
Dogsbody
Re: Finally!
Postby Dogsbody » Mon Dec 21, 2015 10:46 pm
Dogsbody
Re: Finally!
Postby dreinecke » Mon Dec 21, 2015 11:24 pm
Mark - That is all good advice. I'd also use Durhams wood putty instead of Bondo. MUCH easier to work with!
Re: Finally!
Postby acmost » Tue Dec 22, 2015 6:25 pm
Very cool, Full Trigger huh...that looks great - is it finished yet? :)
acmost
Re: Finally!
Postby Dogsbody » Mon Dec 28, 2015 10:05 pm
Track is joined together and the 1st coat is on and yep, thats the color (dark grey) I was after. Next up a bit more prep, some run off needs to be added and then the braids go on and then the final coat.
Dogsbody
Re: Finally!
Postby Broman62 » Mon Dec 28, 2015 10:18 pm
Re: Finally!
Postby Dogsbody » Tue Dec 29, 2015 9:43 am
Thanks, Gents. I can do the final coat before I lay the braid and I do have the braid tool from SCC. Looks like it could be a weapon all by itself...
Dogsbody
Re: Finally!
Postby acmost » Tue Dec 29, 2015 9:52 am
Are you done yet!!!
acmost
Re: Finally!
Postby TuscoTodd » Tue Dec 29, 2015 10:08 am
That is lookin' good!
:handgestures-thumbup:
Re: Finally!
Postby HomeRacingWorld » Tue Dec 29, 2015 5:15 pm
It is a Braid Sabre. Only Slotcar Jedi should use it:-)
Re: Finally!
Postby Dangermouse » Tue Dec 29, 2015 5:51 pm
Every time I read these new track build stories I want to go out and build another track :)
Looking really good....
Dangermouse
Re: Finally!
Postby Dogsbody » Tue Dec 29, 2015 7:50 pm
What a thankless job laying down the tape and then the braid is... Next time, I'll pony up for the braid that has the tape already on it. Anyway, this part is done. Now to to the wiring...
Dogsbody
Re: Finally!
Postby dreinecke » Tue Dec 29, 2015 10:43 pm
This track looks excellent! Wow! Can't wait to play.
Re: Finally!
Postby Dogsbody » Mon Jan 04, 2016 8:03 pm
Looking for suggestions for a guardrail of sorts. I need it to be about 2" high so the wings on the 1/24 don't get caught on them. I looked at some solid strip plastic thats used for bathrooms but it was too thick and the stuff that was thin enough wasn't tall enough. It needs to be able to bend pretty easily too.
Dogsbody
Re: Finally!
Postby ccobra » Mon Jan 04, 2016 8:39 pm
ccobra
Return to The Lumber Yard
