Home Racing World • View topic - "I can't drive 55" - 55 Sportsman WIP
Postby HomeRacingWorld » Thu Nov 19, 2015 3:20 pm
Time for the second Sportsman Showdown project. This time we roll back the time a couple more years to 1955. The 55 Chevy might just be the icon of early stock car racing. I've seen many a photo with a turn full of these hammers going at it. Anyway, the mail ran today and dropped off the usual SCC jewelry box so it's time to get started.
This isn't the first 55 I have ever done as this model has been around a long time. MT made a great mold of it so I am using it in stead of the usual Snap-Tite kit.
As old Smoke and Fred look things over in the body department, time for another installment of Harry's Almost Useless modeling tips :)
Making a simple flat tray interior is easy for most and really doesn't need much of a tutorial. BUT I have had more email about it so here we go.
I like using the Plastruct diamond plate for effect. When you are finished it adds just a bit more scale appeal to me so it's worth the investment. The roll bars I make from the Evergreen rod. I just use a lighter to heat and bend. Testors model glue holds it just fine. I use just about anything for a dash panel, but left over clear lexan works great. Best use of a cheap commercial blob body I can think of. They are found very cheap and the best part is using the pre-molded windshields for other models when you want or need a curvature shape. If not, you can see I save all sorts of blister packs and have even picked up some clean K&S sheets. ANOTHER HINT: Save those soda bottles! A good 2 liter bottle also makes a great source for windshields :)
Once spray painted flat black I think it looks ok. No modeling awards here, just a basic interior that you can fine detail if you wanted to.
Works for our racing :)
Ok, time to heat up the old iron...stay tuned. :auto-checkeredflag:
Re: "I can't drive 55" - 55 Sportsman WIP
Postby btaylor » Thu Nov 19, 2015 4:25 pm
Gotta love the 55 Chevy's. they make some great stockers.
Watching this one too Harry!
Postby Audi1 » Thu Nov 19, 2015 5:22 pm
That interior looks sharp! Looking forward to seeing the progress on this one.
Postby HomeRacingWorld » Thu Nov 19, 2015 9:18 pm
LOL :whistle:
Let me know when the mail arrives tomorrow.
Postby SlotCarCorner » Thu Nov 19, 2015 9:45 pm
SlotCarCorner
Postby dreinecke » Thu Nov 19, 2015 10:41 pm
This is going to be killer!
And what IS the scoop with the mat you crazy man?
Postby CrockettNZ » Thu Nov 19, 2015 11:48 pm
my favorite car of all time
the soda bottle for windscreens sounds like a good idea
will have to give that a go
I to put those blister packs to good use for interiors
CrockettNZ
HRW Pit Mats
Postby SlotCarCorner » Fri Nov 20, 2015 5:45 am
SlotCarCorner
Postby Gentleman Norb » Fri Nov 20, 2015 7:46 am
Always a favorite of mine. I am sure it will be a great runner Boss.
Gentleman Norb
SlotCar Aristocrat
Re: HRW Pit Mats
Postby Gentleman Norb » Fri Nov 20, 2015 7:48 am
Gentleman Norb
SlotCar Aristocrat
Postby HomeRacingWorld » Sun Dec 06, 2015 7:32 pm
Well, been kinda wild around here but back to the shop.
In testing the JK F1/INDY bracket, we know it has a .055" offset. I wasn't sure if an offset crown was really needed so I tested both a standard and offset Slot.it crown. After a few test runs it was clear the offset crown is the better choice. Much smoother gear mesh as expected.
Rest of the chassis is now completed and doing some final test laps.
I also put in a little offset to the motor, but not a lot.
Ok, back to work :)
Postby HomeRacingWorld » Sun Dec 06, 2015 8:39 pm
Used the NYmodifieds insert. Apple Barrel acrylic red with a thinned black wash.
Did not sand the back to create spokes this time. Think it will work ok.
Postby HomeRacingWorld » Sun Dec 06, 2015 9:16 pm
The offset is the relation of the motor shaft to the axle.
So with this bracket, the motor shaft is .055 lower than dead center.
Postby bill from nh » Mon Dec 07, 2015 8:50 am
All of JK's 3/4" wide motor brackets (JK-D3F122)have this offset. Their 1" wide motor brackets are available both with (JK-D322) & without (JK-D321) the offset.
bill from nh
Postby padirtfan » Mon Dec 07, 2015 9:46 am
Is MT Resin's down? I've been trying to get on the site but it won't let me.
padirtfan
