Monogram Petty Plymouth!
Share Your Thoughts!
Re: Monogram Petty Plymouth!
Postby dc6287 » Thu Sep 13, 2012 2:55 pm
Just ordered this car. Can't wait to get it, as it's akward being the only guy w/ a Carrera in a field of monograms... but that's a story for another time!
Dan C.
dc6287
Postby HomeRacingWorld » Thu Sep 13, 2012 9:16 pm
Well, this is a great thread. Thought I would chime back in with my car fully tuned.
Performed all the mods I show in the tune up article. Used the silver SCC Steelies with PG21105 tires. Painted the wheels with Krylon silver and also the fronts to make them match.
I buffed it with Johnson paste wax to clean it up a bit and help protect the decals.
Yes, my mods are little extreme...but they get the car to run the way I like it to on the wood.
Seeing this car haulin' around is a great sight. We needed the King and we got him, I'm pretty darned happy.
Postby Nor Cal Mike » Thu Sep 13, 2012 10:28 pm
Lookin' good Boss.
Nor Cal Mike
Postby Nor Cal Mike » Fri Sep 14, 2012 10:44 am
I continue to work over my #43 Plymouth and am very pleased with it thus far. I pretty much followed Harry's tune up article with the exception that I have not replaced the braids and wires yet and I stayed with the stock axle set up. I did lower the rear of the body a tad, just enough to make her level. I did the super glue trick to the axle, sanded the stock tires (rounded the edges of the tires too) added a big haunch of brass plate at the bottom of the chassis. Otherwise she is Monogram stock. She definitely is a winner.
Nor Cal Mike
Postby HomeRacingWorld » Fri Sep 14, 2012 11:02 am
Looks good to me :)
I smell a HRW FunRun Proxy coming.
Postby Nor Cal Mike » Sat Sep 15, 2012 9:30 pm
Well, now I've got the bug. I just ordered the Holman Moody/ David Pearson Fairlane. Now there is a historic duo.
Nor Cal Mike
Postby HomeRacingWorld » Thu Jan 03, 2013 9:32 am
I am almost enjoying you having a new oval as much as you are :)
it might be that all these roundy-rounders that have been laying around here will get more and more track time.
If you need any help at all with the car, I will be glad to assist. But I think you know exactly what to do.
Look forward in hearing your garage report after you wrench on it some more.
Postby dreinecke » Thu Jan 03, 2013 12:00 pm
I think the Chinese have resorted to having gorillas assemble these things. I've had 2 with bent axles on these - but now I'm seeing it on 2 Scalextric cars as well. Completely bent rear axles. Can't wait to see what you end up with when it is all together.
Postby Cosmic Bilby » Thu Jan 03, 2013 8:09 pm
....The boss questioned me about this car when I took it out of the package from Bruce the other day....
She wanted to know why I had so many of the "one car" in my rev/mono/Carrera Stocker collection (Sky Blue colour)
I sat down and showed her that they were indeed all different, and explained that the blue is Petty Blue.
My world once more became tranquil....
Cosmic Bilby
Postby Burglar » Mon Jan 07, 2013 9:35 pm
David I toss the rear axle out on these if I plan to race them. Quite a few come with bent spurs. I need to get back to my Hurtubise project. The main thing that annoys me is warps in the chassis, because straightening them is messy and involves a lot of stuffing around. Replacing axles is expensive but not too difficult, and changing the wheels to SCC makes a huge difference. Up front I always replace the guide on these for a screw-fit one, but I think that the main thing is to get rid of those awful braids and get the guide closer to the track. I also like to swap the motor out for one with better braking, as I do a lot of 'Riverside racing' and I don't want my car bounding off the track in the corners like AJ Foyt did that time
Burglar
Return to Product Reviews!
