Home Racing World • View topic - Dungeonracer's Show me Showdown Special
Re: Dungeonracer's Show me Showdown Special
Postby Gameover » Thu Oct 22, 2015 12:54 pm
lol just never seen it for this application. thought it was a cool idea!
Postby btaylor » Thu Oct 22, 2015 1:03 pm
It is a great idea, and I look forward to seeing the car when it gets that far. really good start on it already. I like that full pan design.
Postby nhdungeonracer » Thu Oct 22, 2015 10:12 pm
:lol: Gameover, they say there are no dumb questions, but you can sure get some wise ass answers... :lol:
For the body, it's going to be a Ford for sure.
I may have run into a snag with this chassis :doh: Am waiting for a reply from the Boss :whistle: He did mention he was going to be busy this weekend.
Postby nhdungeonracer » Fri Oct 23, 2015 10:36 am
Ok, spoke to the Boss...
The snag was that after putting on the running gear, I didn't have the proper ground clearance, not even close. Guidelines state 1/8" (or .125"), and I only had .080". So I need to raise the whole chassis up some. The Boss has gave me a few ideas on how to go about it. Looks like I'm going to remove the motor mount and do some filing so the "frame rails" are higher on the mount which will raise the chassis...
The body has just come out of the dipping tank. A little more dremeling (arrrgh!!!), and it'll be ready for it's new paint scheme.... :banana-dance:
Postby nhdungeonracer » Mon Oct 26, 2015 10:19 am
Postby HomeRacingWorld » Mon Oct 26, 2015 10:24 am
Looking good. Great way to show the work on that bracket.
You are hired. Please go to Helen Waite, our finance manager for lucrative contract details.
Postby TuscoTodd » Mon Oct 26, 2015 10:35 am
Great solutions to getting the added ground clearance!
Where there is a will, there is a way! :D
Postby bill from nh » Mon Oct 26, 2015 1:43 pm
Dickie, you're using BWA's forged brackets, rather than PM's. These don't have the side grooves made in, but have two .047 holes in the face. Also, the BWA is drilled for mounting 16D's as well as FK cans. The PM bracket is not.
bill from nh
Postby nhdungeonracer » Tue Oct 27, 2015 11:46 am
Postby nhdungeonracer » Tue Oct 27, 2015 11:51 am
Postby nhdungeonracer » Wed Oct 28, 2015 8:27 am
Postby slothead » Wed Oct 28, 2015 9:48 am
Do you know what your ground clearance is now? Was the initial problem because the brass plate was under the rods coming off the motor bracket? I'm assuming the clearance is fine at the motor bracket using the designated wheels and tires, but you can't have anything that is below the bracket. Does that make sense?
Murphy is never far away during a build - no matter what we're working on. I try to diminish his by making drawings on graph paper of my ideas, but something still always goes wrong.
Slothead
slothead
The Doctor is IN!
Postby nhdungeonracer » Wed Oct 28, 2015 10:00 am
The chassis is now right at the recommended .125" height.
With the designated wheels and tires, the clearance is right at the .125" mark on the bottom of the PM (or BWA?) motor bracket. So yes, anything that is lower than the bottom of the bracket would essentially be below the designated height. At least that's my experience... ;)
Murphy was here during this build for sure. I kicked him out a few times, but I guess I kept forgetting to lock the door after doing so, cuz he kept coming back.... :lol:
Postby HomeRacingWorld » Wed Oct 28, 2015 10:08 am
Looks like a race car in the making to me. Well done!
Postby btaylor » Wed Oct 28, 2015 10:57 am
Your chassis looks great to me. I like a solid, somewhat heavy build for mine. I find they handle a lot better through the corners.
If something didn't go wrong at least once during a brass build, I would get worried!
Nice job on that one, should be a runner.
