Old #17
Old #17
Postby HomeRacingWorld » Mon Dec 31, 2012 9:57 am
Here is another old hammer that has been neglected far too long.
Yes, far too long. Chassis is cracked, so is glass. Glass will run as is, sort of like the look :). Will go SCC Steely 17's and full Slot.it rear end as I have no other gear worth putting on it.
Front end I have spares, will repaint.
Body is rough. Gave it a bath and I should touch up the bumpers...but not sure. Sort of like the old warrior's looks as is. Will polish it up and decide.
Curly isn't too happy with me taking away from his collection...but I did make a New Year resolution. :whistle:
Re: Old #17
Postby HomeRacingWorld » Mon Dec 31, 2012 10:51 am
Yes, I know you are waiting with baited breath for the next installment. Calm down adoring fans, it's time for an update :confusion-waiting:
This old chassis has a crack in it right where the bushing sets.
I held it back in place and used Super Glue to hold it. Then used a very thin section of styrene plastic over it. I sanded the section first to score it so the glue had more to bite into.
Did the backside too. I made the braces low enough so the bushing flanges would clear.
Now to clean up these bushing mounts and get our new bushings in place.
Stay tuned!
Re: Old #17
Postby dreinecke » Mon Dec 31, 2012 10:54 am
I'm still trying to figure out how Curly and Destiny allowed themselves to be separated...
Nice fix on the crack, I look forward to seeing this one done!
Re: Old #17
Postby waaytoomuchintothis » Mon Dec 31, 2012 10:57 am
Doing the few things the rules will allow (as I like it), on the Mini for Bruce's Cincy Proxy, I have been thinking a lot about the many cars I have neglected, and the ones no one else around here cares to race. I figure I can swap out these cars that never do anything for fancy parts for my favorites, and come out much happier with both situations. Frankly, I can't wait to get started.
Re: Old #17
Postby hoganracing » Mon Dec 31, 2012 11:05 am
The way you were describing this one I thought it might become one of the venerable Carrera Bombers!
Patrick
hoganracing
Frequent Flyer
Re: Old #17
Postby HomeRacingWorld » Mon Dec 31, 2012 11:12 am
No Mr. Flyer, not this one...but stay tuned.
Re: Old #17
Postby ourwayband » Mon Dec 31, 2012 4:47 pm
Look forward to this rebuild.As a wise one told me,any car can be fixed now due to the great parts supplied by the many guys adding to this hobby..Keep us updated Harry!
Re: Old #17
Postby HomeRacingWorld » Mon Dec 31, 2012 5:23 pm
That is true, whatever fart smeller...I mean smart fellar said that is right.
ONLY if the guy is smart enough to order all the parts. Can you guess who isn't, and has to wait until Wed? :)
Re: Old #17
Postby HRWJim » Mon Dec 31, 2012 6:44 pm
I have one waiting for parts now. I checked the mail box 3 times today. LOL Jim
Re: Old #17
Postby Burglar » Mon Dec 31, 2012 8:09 pm
Try running one of those dremel lawnmower blade sharpeners (like you get in the SCC bushing alignment kits) through the bushing holes first. My guess is that if it cracked maybe the hole was a little small/tight.
Hopefully this helps as I know the earlier Carrera has a different bushing, but I think the diameter is the same.
Burglar
Re: Old #17
Postby FootScoot » Sat Jan 05, 2013 8:26 am
Nice fix on the cracked chassis. I've had that happen, but didn't use super glue as the plastic on chassis' is a different breed. I used PVC cement with the styrene patches which really bites into the chassis plastic. The cement is the same stuff you use on plastic PVC pipes. It's cheap too and can be purchased a lot of places around town. :)
Re: Old #17
Postby HomeRacingWorld » Sun Jan 13, 2013 6:48 pm
This one took awhile, but got'r done.
Chassis was cracked up front too. Found that out fitting the B-Nova. After all the glue and styrene were added, it took a good sanding to get the body to sit right and to get the front axle to ride correctly. I sanded out the front bushing mounts and just let the axle "float" while on the setup block and then glued in place.
SCC 17x8 Steelies, PG 22155 tires, Slot.it 27 Crwon and 9 tooth pinion. Stock motor.
The old fox is back though, ready for action.
Re: Old #17
Postby HomeRacingWorld » Sun Jan 13, 2013 7:39 pm
Yes, and a bottle of Old Crow :)
Re: Old #17
Postby waaytoomuchintothis » Sun Jan 13, 2013 7:54 pm
Oh no. Do they still make that stuff? I suppose people still need to strip paint off steel from time to time.
What did you do with the balance, Harry? I always had trouble getting the Torinos to balance weight for good handling.
Re: Old #17
Postby HomeRacingWorld » Sun Jan 13, 2013 8:20 pm
Well, I lowered it a little in back. Just shaved the rear mounts flush with the bumper tabs. This really helps, even though it is only a little.
The big thing with the Fords is something Cheater showed me a long time ago: Open up those screw holes! They molded them slightly off and this causes a bad tweak in the chassis. Once you free it up, then the car starts to act right :)
Return to The Slot Car Garage
