by gascarnut » Thu Sep 03, 2015 7:10 pm
Guys,
Remember that the diameter of the solder you are using does not help to control how much ends up on the frame if you carry the solder to the chassis on the iron.
What you want to practice is to heat the joint enough that the brass melts the solder, then you have a better chance of controlling how much solder is applied. Lots of flux helps with this, especially liquid flux, as it provides better thermal contact between the iron and the work.
There are times when you iwll need to carry the solder on the iron, like when you need just to tack something in place. That's OK, but be careful how much solder you use, it is surprising how little is needed t tack something when the parts fit closely.
And that's something else to consider - the better the fit between your brass (and wire) pieces, the stronger the frame with less solder. You really don't want to be trying to fill mis-fitting gaps with solder, that's just weight and it looks messy.
In one of the other threads, Harry said something about a good set of files - very sound advice.
