flared Porsche 356 speedster
Postby VTECFOUR » Mon Jul 13, 2015 1:38 pm
Got this flared Porsche 356 speedster into my head after some members' (Audi1, retroracer44) thoughts.
Cast a 356 resin body from my mold and gathered up some parts for a sidewinder build.
It's got quite a wide track at 2 5\8". I know it couldn't make it up Luf's Burnaby Grind Hillclimb smashing into the rock faces all the way up and down, but what about the Dragon Tail?
VTECFOUR
Re: flared Porsche 356 speedster
Postby VTECFOUR » Mon Jul 13, 2015 10:13 pm
Scrounged through the parts box and found one of my adjustable wheelbase chassis builds. This'll help expedite the build. It uses a Winpod FF050 motor pod via Shapeways with a TSRF guide.
Ranch Design rims will make it roll with PG tires on the front and my own urethane re-pops of the Fly March F1 tire for the rears.
I'm going for this stance.
The wheel/tires used won't be "scale proper" for a 356 but I'm leaning more towards performance and a low profile on this one.
Stay tuned.
VTECFOUR
Postby dreinecke » Tue Jul 14, 2015 6:46 am
Your are a crazy man...I love the March F1 monsters out back! Very clean chassis too.
Postby HomeRacingWorld » Tue Jul 14, 2015 1:34 pm
Yes, this could a Dragon beater.
Postby Gameover » Tue Jul 14, 2015 1:40 pm
yep another flared dream!!!
Postby VTECFOUR » Tue Jul 14, 2015 10:33 pm
Chassis's up and running. Power's from a stock Scalextric FF050 motor with 9/27 gears.
Runs well.
Modified BWA American Racing 5 spoke inserts were mocked into the rims. Look fine.
Body mounting's next.
VTECFOUR
Postby SLOTTING SINCE 1963 » Wed Jul 15, 2015 10:47 am
That looks like it won't have to do the Walk of Shame.
Richard.
SLOTTING SINCE 1963
Postby Audi1 » Wed Jul 15, 2015 1:22 pm
That is one nice build!
I was thinking..........maybe we need a fat 356 proxy fun run(?) If that has any traction on this forum, could you pop a few more bodies............?
Postby Gameover » Wed Jul 15, 2015 1:29 pm
id be in if the bodies where there!
Postby Retro Racer 44 » Wed Jul 15, 2015 2:26 pm
I think it is time for a Tub proxy, two classes two body styles.
Classes would be stock and open, either roadster or coupe.
Stock would be uncut, unflared, <15K motor. Open could be flared to the max, and as much motor as you dare. All cars on urethane tires, stock has limit of 7.5mm on the tread, open just have to be covered by the flares.
Good idea, eh?
Retro Racer 44
Postby TuscoTodd » Thu Jul 16, 2015 7:29 am
That is shaping up to be one sweet looking build! :D
Might have to look at jumping in if there ends up being a proxy for these, with bodies available, etc! :D
Postby VTECFOUR » Thu Jul 16, 2015 5:34 pm
Some progress.
Added .064 pans to the chassis for a total body/chassis weight of 97g.
Predictably, it's got a more planted feel. Loosened the motor pod at the back. Not as fast a my flared Mini pick up but pretty good.
For sure, the look's transformed. Not better, just different.
Modelling (cockpit opening, driver figure, rollbar) and paint are next.
As for making bodies available, I'll think about it.
VTECFOUR
Postby buspor63 » Thu Jul 16, 2015 9:28 pm
Slap a PAP (Porsche Auto Parts) sponsorship on there with a #96 and you have a 1980's SCCA E Prod racer.
buspor63
Postby VTECFOUR » Fri Jul 17, 2015 3:08 pm
Driver figure and rollbar's in.
Got some performance improvement by enlargening the chassis's rear mounting holes allowing sliding action.
Primer's next but stil undecided on paint finish.
VTECFOUR
Postby Audi1 » Fri Jul 17, 2015 6:31 pm
Looking really good! Nice work with the driver and the rollbar. Is the rollbar attached through to the chassis or to the body, and if to the body, then how was it attached? Metal or plastic?
