Rear lights for a Carrera 917K 1/124
Postby buspor63 » Sun Mar 15, 2015 4:34 am
The car is great without the lights, but I wanted the look. I used some 3mm, 3000 mcd red Led bulbs, some hookup wire and tapped into the rear light circuit on the digital chip. The bulbs are mounted in some plastic tubing that I inserted just on both sides of the spare tire.
buspor63
Re: Rear lights for a Carrera 917K 1/124
Postby buspor63 » Sun Mar 15, 2015 4:39 am
This is the view underneath. The tubing is cut flush on the inside of the bulkhead so the motor pod will pass by.
buspor63
Return to The Slot Car Garage
