Home Racing World • View topic - New Jalopy Build "Semi Live Coverage - COMPLETE"
Postby HomeRacingWorld » Fri Sep 07, 2012 9:56 pm
Ok, I really need to start a Jalopy. Been a lot of work going on and not enough play this week :)
I thought I would do a "Semi Live" project, just posting progress as it happens.
So here is the start. DTR repop kit. NO, it does not come with any Jalopy parts, just a standard kit.
Old Protrack chassis I found while cleaning this place before the Labor Day event.
Paul Gage custom made tires. He has made several of these tires from model kit tires I have sent in.
Big Donkey resin inserts.
I have NO idea what it will look like. Just getting started :)
More to come soon.
Re: New Jalopy Build "Semi Live Coverage"
Postby RazorJon » Fri Sep 07, 2012 11:55 pm
come on I thought you are doing this live :dance:
Postby MoparGreg » Sat Sep 08, 2012 12:43 am
Do you have this thing built yet? Just joking, Looking forward to what you come up with. Now get building!
MoparGreg
Postby HomeRacingWorld » Sat Sep 08, 2012 1:11 pm
I am lucky to be this far...Curly doesn't like it when I dig around in the tire pile.
Website work is done, time to play a little.
Postby HomeRacingWorld » Sat Sep 08, 2012 5:33 pm
Frame rail installed.
Precisely measured, weighed and balanced. :text-bs:
Postby HomeRacingWorld » Sat Sep 08, 2012 6:33 pm
Postby MoparGreg » Sat Sep 08, 2012 9:41 pm
looking good Harry. Im just curious what part of the car you will use that pig for?
MoparGreg
Postby HomeRacingWorld » Sat Sep 08, 2012 9:44 pm
Ok, time to mount the front axle housing and build a guide tongue.
I set the chassis in the jig. Not the perfect way, but the way that works for this application for me.
Lines it up just fine. Clamp and solder.
Since I have a lot of scrap brass sheet stock, I used it for my guide tongue. Nothing fancy here, but why waste perfectly good brass? Besides, if Locoracer Tom sees this, he will be happy.
I use a torch for my soldering and having some battery clamps helps hold it all nicely. No, this may not be "textbook"...but it works.
Ok all soldered and runs straight as it can.
These wheels are for setup, but so far it is looking ok.
Time to make up some nerf bars and a chrome horn up front :)
Postby RazorJon » Sat Sep 08, 2012 9:57 pm
now thats looking great, :clap: I just came up from working on a few things and finished one :!:
Postby MoparGreg » Sun Sep 09, 2012 2:08 am
MoparGreg
Postby Gentleman Norb » Sun Sep 09, 2012 7:15 am
Bensenville Bombers Rule Book!?!? :music-deathmetal: :lol:
Gentleman Norb
SlotCar Aristocrat
Postby HomeRacingWorld » Sun Sep 09, 2012 1:16 pm
Heck of a book isn't it? I think JYD wrote it.
Had to start on the body. Needed to know how it would sit.
Decided to go open top. Sanded windows/hinges/mold lines the best I could.
Opened up the radiator. Sanded the back of it so the body would slide back just a tick to look right. Some screen here will make a nice effect I think.
Little low in the rear, but some shims will fix that.
Postby HomeRacingWorld » Mon Sep 10, 2012 8:16 pm
Postby RazorJon » Mon Sep 10, 2012 10:54 pm
what did you use for the rear bumper :?:
Postby HomeRacingWorld » Tue Sep 11, 2012 6:06 am
Scrap copper wire and some K&S brass strip. I will try and find the number sir.
Users browsing this forum: No registered users and 42 guests
