Home Racing World • View topic - Oval Track Heats - Question
Postby Kemtronracer » Thu Dec 06, 2012 2:37 pm
My new oval is almost done(see the Lumber Yard). While working on it last night, my buddy and I were discussing the race format. He thought each heat should be 5 laps, then we rotate lanes. I am used to road course racing where we run for three minutes then rotate lanes. So the question is: How do you run your race program on your oval course. I should mention my track will be four lanes with an average lap of 36 feet.
Thanks in advance for your comments,
Kemtronracer
Kemtronracer
Re: Oval Track Heats - Question
Postby hotrodlarry » Thu Dec 06, 2012 10:28 pm
2 minute heats work real well on a small oval in my opinion. Nice quick race, even if you have a lot of drivers.
hotrodlarry
Postby butterbean72 » Fri Dec 07, 2012 10:19 am
Hi
We do 2 Min. heat's with a minute or two in between to clean tire's etc. We don't do Crash and Burn we use Computer lap counting system . Bean
butterbean72
Postby RichD » Fri Dec 07, 2012 10:43 am
We do timed heats with lane rotations. 1:1 oval racing is done by distance or for a certain number of laps, but 1:1 cars don't have to do lane rotations. I suppose that we could run each heat for a certain number of laps, we have never tried that.
Postby nhdungeonracer » Fri Dec 07, 2012 1:43 pm
On a small track, we do 50 lap heat races. We give out points to the winner of each heat. 5 for 1st, 3 for 2nd, 2 for 3rd, and 1 for 4th. After everyone has run all 4 lanes, we tally up the score (Trackmate will do this for you under 'Championship' mode). Most points is your winner.
It's almost a given that the guy on the inside lane will win every heat, and the guy in the outside lane has to work the hardest to get points. Where it gets interesting is how well you can do in the middle lanes to add to your points total.
Postby Kemtronracer » Fri Dec 07, 2012 7:46 pm
Two minute heats sound great to me. but the "Championship Mode" is also interesting. I guess that keeps someone from getting too far behind to recover if they have a bad heat. When we get to racing I'll give that a try. Thanks
Kemtronracer
Postby RACENUT44 » Sat Dec 08, 2012 8:16 am
ITS HARD TO DO LAP RACING ON A SMALL OVAL WITH THE INSIDE LANE SO MUCH FASTER THEN OUTSIDE LANE.
IT COULD BE 1/2 SECOND A LAP. OUTSIDE LANE GET LAPPED EVERY 4 LAPS.
BUT I HAVE PUT A VOLTAGE REGUATOR ON EACH LANE, INSIDE LANES HAVE A LOWER VOLTAGE AND THE OUTSIDE LANES VOLTAGE GETS HIGHER.
I HAVE A 6 LANE, SMALL OVAL AND ALL 6 LANE ARE WITHIN A FEW HUNDREDS BETWEEN THEM.
MAKE FOR SOME CLOSE ACTION PACK RACING.YOU MAY HAVE 4 CARS IN THE LEAD LAP AFTER 50 LAPS
THANKS DENNIS
RACENUT44
Postby Gentleman Norb » Sat Dec 08, 2012 8:33 am
We run two minute lane rotation heats also. With the squeeze on my oval track the inside lane doesn't necessarily have the advantage.
On the road course its the same rotation.
Gentleman Norb
SlotCar Aristocrat
Postby Kemtronracer » Sat Dec 08, 2012 2:18 pm
Kemtronracer
Postby Kemtronracer » Sat Dec 08, 2012 2:20 pm
Kemtronracer
Postby RACENUT44 » Sat Dec 08, 2012 4:34 pm
ITS A GOOD 1.5V
AND MORE FOR OTHER CLASSES -- 2.0V
BUT MAKES GOOD RACING
THANKS DENNIS
RACENUT44
Postby nhdungeonracer » Sat Dec 08, 2012 8:36 pm
