New Oval Track Build in Mooresville NC
Got Wood?
Your ROUTED TRACK Home!
Postby Kemtronracer » Thu Nov 22, 2012 7:50 pm
I decided to disassemble my roadcourse and use parts of it to build an oval in my basement. It's really more of a tri-oval. Here's a couple of pics of the work in progress:
The track will end up being 18 feet end to end with a 6 foot wide turn at one end. It has four lanes spaced 3.5 inches. As you can see it was a tight fit between the pillar and the wall, but we had just enough room to squeeze it all in. I'll post more pics as the work progresses.
Kemtronracer
Re: New Oval Track in Mooresville NC
Postby HomeRacingWorld » Thu Nov 22, 2012 7:56 pm
Looks good sir. Well done.
Postby hoganracing » Fri Nov 23, 2012 11:01 am
That looks like it will be a fun oval to run. The little dogleg will add a lot to the fun.
Patrick
hoganracing
Frequent Flyer
Re: New Oval Track Build in Mooresville NC
Postby Kemtronracer » Wed Nov 28, 2012 6:55 pm
I finished the last section of the track, then attached it to the table with deck screws. I was able to get a 5 degree bank in most of the turns. Then after a lot of sanding the base coat of paint was applied.
Once the primer coat dried, it was time to paint the lane colors in the braid recess.
Tomorrow some light sanding and then paint the roadbed. I'm thinking a reddish brown like our Carolina clay.
Kemtronracer
Postby eeprof » Wed Nov 28, 2012 7:01 pm
The track is looking good!!!
eeprof
Postby Kemtronracer » Fri Nov 30, 2012 7:08 pm
Got the paint down and the first coat of urethane. I'm still doing some touchups here and there. We plan on laying down the braid on Monday and hope to be running some laps by the end of next week.
Kemtronracer
Postby ourwayband » Fri Nov 30, 2012 7:54 pm
That track is looking Great!!!!
Postby Tubby » Fri Nov 30, 2012 9:25 pm
I love the look of the trioval! Bravo sir, bravo!
Tubby
Tubby
Postby Kemtronracer » Wed Dec 05, 2012 8:05 pm
THanks for all your kind comments. I'm really looking forward to racing on this track. Here's another update: My friend, David, helped me install the braid and the outer guardrails. Tomorrow I'll do the wiring and hopefully get power to the track.
Here's a few pics showing the amount of banking in the turns:
Kemtronracer
Postby Kemtronracer » Fri Dec 07, 2012 7:50 pm
I wired the power to all the lanes today and made a few test laps. The tri-oval is fun to drive as each of the three turns is different and each straight section is a different length. I'm anxious to get the lap counter installed so I can compare times on each lane.
Kemtronracer
Postby dreinecke » Fri Dec 07, 2012 11:01 pm
Really great looking track!
Postby Kemtronracer » Wed Dec 12, 2012 11:30 am
Thanks for your kind comments. I've been making some progress in recent days. The lap counter is installed; the wiring panel covered; and the infield painted. Here's a few pics:
I still need to make some controller holders and tidy a few things up, but the track is fully functional and open for racing.
Kemtronracer
Postby eeprof » Wed Dec 12, 2012 1:52 pm
Nice job!!!!!
The track looks good!!!!
eeprof
Postby Fast Co. » Thu Jan 03, 2013 4:58 pm
That's really looking great Jeff! Can't wait to race on it!
Steve
Fast Co.
Return to The Lumber Yard
