Home Racing World • View topic - Smokey and the Bandit (and Snowman's rig too)
Postby choc-ice » Wed Dec 31, 2014 12:14 pm
So, choc-ice, what have you been doing these last few months?
Let me guide you through my thought process and let you inside that part of my brain that does slot car stuff.
A few months ago I found a remote controlled truck which was 1:32 scale, I thought it would be ideal to use in one of my slot car videos so bought it straight away. Looks great, doesn't it?
Then, I started to think how much it looked like the truck in Smokey and the Bandit and that thought went around in my head on its own for a while. I did some more research and the blue truck's rear cab is wrong; the sleeper part is too tall. But the idea was still whirring around so I bought the Burt Reynolds DVD to stoke the fire a bit.
A little later I found that Revell have reissued one of their trucks from 1980 which is now available for less than $30. I wondered about using parts of it to make a resin bodyshell but the size is enormous; the cost of silicone alone would be horrific plus the difficulty of pouring so much in without it setting before the mould was pressurised - all serious problems. Add in the fact that I could never make it for less than the Revell kit, so instead why not just adapt the kit to use my chassis, just like I'd done with the Scalextric Starsky & Hutch car?
At the same time I was developing my chassis to take both a wider and narrower front end, the Pickup Truck needs a wide front axle and my previous version was expensive.
With a new, wide front axle it looked possible to get my chassis under this truck. Time to start!
To get Sheriff Buford T Justice's Pontiac LeMans I first tried to get a 1:32 scale plastic kit, unfortunately one doesn't exist. I then tried to get another scale which I could get scanned and re-size to 1:32, but unfortunately one doesn't exist. Last chance, how about finding a real car which I could scan in myself and get sized to 1:32? No, nothing I could find in the UK and nobody in the US who was up for helping. Time for a rethink...
I found a 3D modeller who was up for creating one from scratch, so I sent him some photos and after 2 weeks this came back
This was a real pain to get 3D printed, the surfaces need to be stitched together with no "leaks" to be printed and this model just wasn't playing fair. After a couple of failed attempts it eventually went to the printers.
I thought there was no need to do a TransAm, after all Carrera make exactly the right one. A brief search through the adverts found that the Carrera one was now fetching very high prices across the world! I sourced a bodyshell and made a mold to produce resin versions.
After watching the movie I noticed that Sally Field's character spent a long time with her head behind the seat, perhaps because the director wanted to see more of her rear pointing towards the camera? That meant my interior had to be something special.
The wheel inserts were made as high detail SLA parts then cast in resin, the graphics were designed slowly because I'm rubbish at them. But the outcome of the TransAm is really nice I think.
I still have the Sheriff's car to sort out, the front end isn't quite right although the proportions are excellent. Graphics are on order, as is the light bar (if you think it will spend much time with a roof on)
And the truck is progressing slowly too. The kit has plastic tires and the axles are too big so I've designed some wheel adapters to take the chrome wheels as inserts. As my chassis only has one rear axle, I've also designed a trailing axle support for the truck and a set of axle housings for the trailer.
The trailer uses a simple pair of axle supports, with location for a pin guide at the rear. I've got some carbon fibre rod to work as a pin guide, but I might have to insulate it because I'm not sure if it'll short out the rails?
More as it happens!
choc-ice
Re: Smokey and the Bandit (and Snowman's rig too)
Postby pastor bubba » Wed Dec 31, 2014 12:20 pm
That is pretty cool. Looking forward to seeing it completed.
pastor bubba
Postby dge467 » Wed Dec 31, 2014 2:59 pm
You always come up with some impressive stuff!
Postby turbokev » Wed Dec 31, 2014 3:14 pm
This is awesome... I love seeing what you come up with~
turbokev
Postby Ember » Wed Dec 31, 2014 5:35 pm
The interior of Smokey's car made me spit coffee. Brilliant!
Postby dreinecke » Thu Jan 01, 2015 12:15 am
Gareth those are just too cool!!! Loved how Sally Fields is depicted and probably think you're right on why ;)
Postby choc-ice » Fri Jan 02, 2015 2:21 pm
The Avant Slot Dakar truck tires arrived so I built up the rest of the truck. Chassis is pretty simple; the front and rear are separate and the trailing axle is held onto the driven axle by a pair of linkages with clearance holes. It's a good idea in theory...
The set looks good together. Have you bought yourself one of those SnapTite trucks I mentioned earlier? They're a bargain!
Graphics on the side of the truck look good, they come in two parts per side and are massive!
choc-ice
Postby Vintage 1/24 » Sat Jan 10, 2015 11:45 am
Very cool - I like the way you create your own unusual and eclectic subjects.
It is very unlikely that full-size four-door Pontiac from the 1970s was going to make it to mainstream production anytime soon.
Glad to see new Chase-Cars being added and released.
Curious to see how that 18-wheeler rolls around the corners...
Vintage 1/24
Mr. NY Modified
Postby choc-ice » Sat Jan 10, 2015 1:18 pm
choc-ice
Postby dge467 » Sat Jan 10, 2015 7:26 pm
That is too cool!
Postby HomeRacingWorld » Sat Jan 10, 2015 9:21 pm
It is about as cool as it gets. Well done.
Postby dreinecke » Sat Jan 10, 2015 9:38 pm
Make sure you put Fred in the cab of the truck...the Snowman would miss him.
Postby choc-ice » Sun Jan 25, 2015 10:07 am
At last, the first (second generation) out of the mold!
Light bar and wheel inserts were made from my 3D designs done by SLA manufacture which has excellent resolution but almost no strength. Fine for making master models but the component cost is $$$
choc-ice
Postby TuscoTodd » Sun Jan 25, 2015 6:24 pm
VERY cool! :D
Postby dreinecke » Sun Jan 25, 2015 10:43 pm
Gareth - You are a sick, sick man. I LOVE the way this is turning out!!! Where's Jackie Gleason?
