There doesn't seem to be any information on the actual size of the CBD wheels..
Do you guys have a chart? or spec sheet that will show the dimensions of each of the wheels offered?
I'm wondering because a 15x11 Steel style wheel is exactly 11.00mm wide, but the overall diameter is 15.86 and the lip is 14.04
Another example is the 14x12 F1 wheel.. it is 11.45mm wide, not 12 and the overall diameter is 14.40 with the lip being 11.43
So the rib the tire fits over is thicker on the F1 wheel than the steel wheel..
The wheels all look fantastic and are the only aftermarket wheels I use..and I suppose at the end of the day if they look
good and have a wide variety of sizes available the exact size doesn't really matter, but I'm curious if the information is
out there and I'm just not finding it~
Thanks!
