Home Racing World • View topic - Quick Slicks Setup
Quick Slicks Setup
Forum rules
Quick Slicks Setup
Postby Smokeio » Fri Oct 24, 2014 11:21 am
I wanted to pass along a tip for setting up Quick Slicks. This past Wednesday was the first official ”coming out party” for the tire in our club racing where it ran well for me, finishing second in our sports car class by just 6 inches. Similar to other silicone tires where gluing and truing is performed, it takes a little work to get this tire to run to its optimum performance. What I found is even though there is a rounded sidewall, it’s important to continue to round the shoulder of the tire. I also go as far as adding another bead of glue on the outside of the rim next to the rounded sidewall to make sure the sidewall does not come unglued.
Mike
Smokeio
Tire Gluing 101 Tip
Postby Quick Slicks » Mon Oct 27, 2014 8:23 am
For the benefit of one of our competitors who evidently read Smokeio's post and then decided to put his own twist on things, here's a little Tire Setup 101 tip that is commonly used by actual builders and racers. Note this tip applies to ANY brand of tires (including theirs) which is what Smokeio pointed out in his original post ("Similar to other silicone tires...").
If you do glue/true your tires (not everybody does), the area where the glue is most prone to fail is along the inner/outer "beads" of the tire. Again, this has NOTHING to do with the brand of tires you use whether ours or the other guys. Note that 1:32 tires don't have actual beads like a 1:1 tire but this is area we are talking about. The failure can be due to any number of factors - the glue used, how well it was applied, and the lateral loads the tire is exposed to during actual racing to name just a few. To strengthen the glue bond in this area, many of the top builders/racers (such as the teams competing in the Michigan 24 Hour Endurance race and numerous proxy racers) will apply some additional glue. This helps prevent the tire from breaking away from the wheel and helps minimize/eliminate unwanted tire "hop". It also has the added benefit of stiffening the sidewall.
Going forward, we'll do our best to set the record straight and share tire-related tips based on our actual car setup and tuning experience. Most of these tips will apply to any brand of tire you decide to use.
Quick Slicks
Re: Quick Slicks Setup
Postby Oscar Racing » Mon Oct 27, 2014 11:40 am
Can you post a picture of the tires and some of the extra work that is done to them.
Looking for the rounding or profiling of the sidewalls and the additional glue that you add to the troubled spots. :text-thankyouyellow:
What does a great set of tires look like???
A picture is worth a thousand words as they say....
Oscar Racing
Postby Quick Slicks » Mon Oct 27, 2014 12:03 pm
Quick Slicks
Postby Smokeio » Tue Oct 28, 2014 7:54 am
Steve, Not sure who set that car up for you but you really should run tape on the back of the pod.
And look at that tire.... Perfect!
Smokeio
Postby Oscar Racing » Tue Oct 28, 2014 9:24 am
Thank you very much, this is what is it suppose to look like. :bow-blue: ...
Did you run this tire on your skid pad, I am thinking the hudy wouldn't provide this smooth of a tire...
Oscar Racing
Postby HomeRacingWorld » Tue Oct 28, 2014 9:47 am
It would be great to have a detailed tuning article on how this is accomplished. Coming from advanced racers as yourselves, it would be a excellent reference.
If you want to do this, I would be glad to help. I would host and convert the article into a web page.
Tire Tuning How-To
Postby Quick Slicks » Tue Oct 28, 2014 10:19 am
Hello Harry,
We'll be glad to put something together to share with HRW readers. We have a 24 Hour Endurance Race in a couple of weeks - once that is behind us, we'll get to work on the article. The article will apply to any brand of tires - not just Quick Slicks.
Quick Slicks
Postby Quick Slicks » Tue Oct 28, 2014 10:33 am
Quick Slicks
Postby Almafan 55 » Tue Oct 28, 2014 11:03 am
Looks great! Now I need 6 sets of those trued & glued for this 24 hr race, PLEASE! I'll just pick them up at the track. :text-thankyouyellow:
Almafan 55
Postby Smokeio » Tue Oct 28, 2014 11:07 am
Smokeio
Postby Smokeio » Tue Oct 28, 2014 11:09 am
Smokeio
Postby Almafan 55 » Tue Oct 28, 2014 12:00 pm
OOOh I see, my :violence-smack: credit isn't good with you! :angry-tappingfoot:
Almafan 55
Postby nhdungeonracer » Tue Oct 28, 2014 10:14 pm
Rob, don't feel bad...
Your credit isn't good with me either... :?
:lol: :lol: :lol:
Postby Almafan 55 » Wed Oct 29, 2014 3:50 am
Almafan 55
Return to The Tire Shop
