Home Racing World • View topic - MRRC 911's chassis build
For 1/32nd Scale Models
Postby SRQSloter » Fri Oct 12, 2018 4:29 pm
Got some parts today to build twin chassis for these puppies. Going try out these minnows with 10/27 gearing rolling on 15x7's all around and Quick Slick shoes on the rear. Using .055 wire for this build. Along with eliminating the interior and going with a flat tray. Mini drill press should be here sometime tomorrow and I'll get the motor mounts made. Then I can fire up the iron.
:handgestures-thumbup:
SRQSloter
Re: MRRC 911's chassis build
Postby Brumos RSR » Fri Oct 12, 2018 5:28 pm
Rusty, your builds are looking good! What do you think about building one to IPS specs? I'm always recruiting guys for proxy racing.
Brumos RSR
Postby SRQSloter » Fri Oct 12, 2018 8:35 pm
SRQSloter
Postby SRQSloter » Fri Oct 19, 2018 5:38 pm
Got a good start on the first chassis and the wire and brass cut for the second today. Start soldering the second one up tomorrow morning and then start figuring out body mounts and cutting side pans. Hoping they are rolling Sunday.
This little puppy made life easier making motor brackets.
SRQSloter
Postby waaytoomuchintothis » Fri Oct 19, 2018 6:40 pm
That's a slick-looking drill press. I guess everything gets prettier as time goes on. But you are definitely set up for good work. Me and my antique-looking tools look forward to some good stuff from you.
Postby HomeRacingWorld » Fri Oct 19, 2018 8:27 pm
I agree with his majesty, that’s an interesting drill press.
Not to ignore the build, looks very good. But some of us are easily distracted, and new power tools do that.
Postby SRQSloter » Sat Oct 20, 2018 2:23 am
Thanks Harry and waay, Works good for what I need it for. Definitely not made for steel it lacks on the power side. But, does brass fine and is pretty quite I was surprised. Has three speed ranges and variable speed control. I had to chuckle when I pulled from the box. Weighs 12 lbs. and 13.5 inches tall. It's all cast iron except for the pulley cover and switch housing. Found it on the bay. They had it priced for 65$ with make an offer so, I made'em a 55$ offer. :banana-dance:
SRQSloter
Postby SRQSloter » Sat Oct 20, 2018 2:01 pm
Twins are coming along.
SRQSloter
Postby VTECFOUR » Sat Oct 20, 2018 7:24 pm
Hi Rusty,
Those chassis are coming along nicely.
Knew you'd miss your old Micro Mark drill press, but the new one looks just fine for light duty tasks.
VTECFOUR
Postby SRQSloter » Sun Oct 21, 2018 12:32 pm
Thanks Dan! Yeah it don't have the power of the micro mark that's for sure. :) Does what I need it to do though.
SRQSloter
Postby Brumos RSR » Fri Jan 18, 2019 11:30 am
Rusty, would love to see an update on the twins
Brumos RSR
Return to 1/32 Showcase
