Home Racing World • View topic - Small drill press?
Small drill press?
Re: Small drill press?
Postby Ember » Wed Aug 13, 2014 3:49 pm
You guys are spoiled for choice at reasonable prices. That MicroLux one would be great.
Postby Tycosaur » Sat Aug 16, 2014 5:19 am
They also work great for pulling and pressing in axles.
Tycosaur
Postby Audi1 » Wed Aug 27, 2014 4:09 am
I need to get one to drill precise holes in plastic (up to 3mm thick) and brass (probably 0.040 naval brass, mostly). Precision is the most important point for me.
Postby Audi1 » Thu Aug 28, 2014 2:01 pm
Postby Ember » Thu Aug 28, 2014 3:12 pm
Postby Audi1 » Thu Aug 28, 2014 6:10 pm
They do.............it's called "the new addition".................. ;)
Postby Ember » Thu Aug 28, 2014 6:22 pm
Around here it's "Yet another shed" :) I have as much shed space as house space. Tiny little cottage.
Postby ddyke » Fri Aug 29, 2014 11:39 am
There are better mills than the Proxon for less money. Check out Micro-Mark's offerings.
ddyke
Postby waaytoomuchintothis » Fri Aug 29, 2014 2:11 pm
I don't know if they are still available, but my milling machine is from Harbor Freight, and was the identical machine to the MicroMark mill, for much less. I was very worried about quality from HB, but I checked it very thoroughly when I was setting it up, and found no flaws at all. But watch out for any of them anyway. The Chinese manufacturers change quickly, and the Chinese make all of them, unless you restore an old mini mill from a US, UK, or German outfit.
Postby waaytoomuchintothis » Fri Aug 29, 2014 2:21 pm
Come to think of it... Lee, what did you buy?
Postby Ember » Fri Aug 29, 2014 3:33 pm
Ok guys. Remember I have shipping to deal with. I love some of the MicroMark stuff, but I'd nearly find it cheaper to pick it up in person than ship it.
Postby waaytoomuchintothis » Fri Aug 29, 2014 4:28 pm
My friend on the North Island of NZ had me buy him an RC airplane and take delivery, then mail it to him myself. You may want to research that and see what you find. He saved over $100US.
Postby Cobra Freak » Tue Sep 02, 2014 12:00 pm
Depending on the work you're going to do there is a pretty thriving market for older Unimat lathe/milling machines. I just picked one up in trade. They convert from lathe to: mill; drill press; bench grinder; jigsaw; circular saw. There are several companies that support them parts wise and tooling is easy to come by. If you are just doing hobby work on slots, or trains, or other small projects they will work just fine for those applications. I would not try and use a drill press to do even light milling. The bearings won't handle the load, and you'll ruin your chuck. Not to mention your work quality will be for S**T!
Cobra Freak
Postby waaytoomuchintothis » Tue Sep 02, 2014 12:10 pm
Well, yeah. Obviously, using a drill press for milling is only for plastics and the like.
Postby masmojo » Tue Sep 02, 2014 2:30 pm
That Micro mark looks pretty good, but if you need another option, I have this in the For sale section.
viewtopic.php?f=26&t=7132
It's pretty much a high precision Dremel machine, you can get a drill press accessory for it. (that's almost the only option I did not get)
I realize it's on the pricey side, BUT it's So much more then a small drill press!!
jus sayin
masmojo
Return to SlotCar ToolTime
