Is Goo Gone OK for use on bodies?
Custom Paint Job Showcase
Postby goosenapper » Mon Sep 23, 2013 7:48 am
I recently tried stripping an old Ninco Ferrari 250TR, but found that the body wasn't painted after all, and merely was bare plastic with stickers applied. The stickers came off following a night spent in an alcohol bath and with a little scrubbing, but I can't seem to get the glue residue completely off of the body. I generally clean a body with regular Dial soap before painting, but even that isn't able to completely remove the glue. That leaves me thinking that Goo Gone would probably get the job done, but I'm concerned that it may adversely impact the body. I'd rather not melt or warp this particular body as it would be hard to replace.
:?: Has anyone successfully used Goo Gone on a slot car body, or failing that, are there other alternatives that I should first try?
Thanks!
goosenapper
Re: Is Goo Gone OK for use on bodies?
Postby HomeRacingWorld » Mon Sep 23, 2013 8:14 am
I would just wet sand those areas a little sir.
Also a little Ronsonol lighter fluid on a paper towel works sometimes.
That Goo Gone stuff will eat the plastic. Been there...sadly.
Postby goosenapper » Wed Sep 25, 2013 9:16 am
Thanks for the insight, Harry. I'll soak some sandpaper overnight and will give it a go tomorrow.
It's a shame that you've experienced the Goo Gone eating a car first-hand, but that's the very reason that I asked. Thanks for the caution on that.
goosenapper
Postby HomeRacingWorld » Wed Sep 25, 2013 10:21 am
No problem.
And you know it had to be on a Fly Classic right?
Postby oldtymer » Wed Sep 25, 2013 7:50 pm
did you try WD40 ? I use that to remove the sticker glue off of the plastic windshield of my snowmobile every year and it works
oldtymer
Cat Lovers Club Prez
Postby FootScoot » Thu Sep 26, 2013 6:39 am
A lot of times to remove adhesive residue I use good ol' Ductape. Take a piece that fits the area, burnish down and lift slowly. The residue will usually stick to the Ductape, if not just repeat until it's all gone. No body damage from chemicals, or sanding. :)
Postby HomeRacingWorld » Thu Sep 26, 2013 7:49 am
Now there is a great tip.
I will try that.
Postby racer6583 » Thu Sep 26, 2013 9:14 am
I have had some great results with finger nail polish remover the acetone in it won't hurt plastic the down side is it takes a bit to get the sticky stuff off.
but it works.
racer6583
Postby goosenapper » Thu Sep 26, 2013 9:25 am
Thanks for the alternatives, guys. I've got residue stuck on a couple of places on the car, so I'll give each method a go.
goosenapper
Return to The Paint Booth
