69 Camaro Flake Paint
Custom Paint Job Showcase
Re: 69 Camaro Flake Paint
Postby DixonJohn » Wed Jan 22, 2014 1:01 am
J Y D I'll put a tutorial up in a few days and show how I did it. I can tell you now, I hope you like the smell of clear. It takes alot to fill it all in. STAY TUNED
DixonJohn
"The Mayor"
Postby Foamy » Thu Jan 23, 2014 4:22 pm
How do you shoot real flake and have it lie down? It seems that when I try, the flakes stick on edge and not flat. Need more air pressure? 35 lbs and Iwata airbrush. . .
Foamy
Postby ecr » Thu Jan 23, 2014 8:33 pm
-Dixonjohn
Very nice paint job,I hope it won't catch air as my gasser willys did :o
It would be a absolute shame. :(
- Shotgun
THANKS... for the weather report,it's -2 below zero,has been all week :angry-tappingfoot:
COLD enough to freeze the nuts off a steel bridge. :laughing-rolling: :laughing-rolling:
ecr :character-oldtimer:
ecr
Postby ecr » Thu Jan 23, 2014 11:51 pm
yep i know
Thanks
ecr
Postby DixonJohn » Fri Jan 24, 2014 1:30 am
Foamy,
I used whatever pressure the airbrush compressor sprays at. I have no clue. Probably between 20 to 30 lbs. When I did this one I had the paint fairly thin and I just kinda never stopped spraying. I did the top, moved to a side then front, other side, rear. By the time I was done with the rear I just started all over again. That's the cool thing with nail polish is that it dries fairly quick. Another thing that will help is get a bit closer. Turn your pressure down to where the paint will come thru the airbrush.Then get fairly close and start spraying. I was at the most 4 inches away from the body.
If you mix your own, Go with the Micro Flake. I think it's like .004. I know they have a flake that is .008. Do a google search for FLAKE PAINT you should find several companies including ROTH. The Roth site also sells rattlecans pre mixed with the stuff. It's expensive though.
DixonJohn
"The Mayor"
Return to The Paint Booth
