Axle Question
Axle Question
Postby swampdog12345 » Sun Nov 02, 2014 9:25 pm
I can't seem to find brass tuning listed by inside diameter. What OD tubing do you guys use to hold 3/32" axles? I am ready to try building my first brass chassis. Thanks!!
swampdog12345
Re: Axle Question
Postby Ember » Sun Nov 02, 2014 9:44 pm
K&S #127 is 1/8" OD. Fits 3/32 axle like a glove.
Re: Axle Question
Postby waaytoomuchintothis » Sun Nov 02, 2014 10:34 pm
Took me a while, then I remembered how I hit "n" when I aim for "b". I really have to stop typing when I'm like that. Anyway, at almost midnight my time, yes, Ember is exactly correct. I think I'll go to bed.
Re: Axle Question
Postby dr fabio » Mon Nov 03, 2014 2:53 am
What you want is 5/32 tubing for the entire length and insert a small 1/8 tube about 3-4mm long as the "bearing" on each side. Amaze your friends as your front axle spins for 3 times as long as your friends tubed axle. The reduction in friction is huge!!
dr fabio
Re: Axle Question
Postby bill from nh » Mon Nov 03, 2014 8:04 am
With K&S round tubing, I remember that the OD is always 1/32" larger than its ID. This works for brass & aluminum, I'm not sure how their stainless runs.
Dr. Fabio, yes, that's a good trick with the front axle tubing. I first saw that being done on brass/wire chassis in the early 70's. Drill a small hole or make a short slit on both ends of the front axle tube. Either will make lubricating the front axle much easier.
bill from nh
Re: Axle Question
Postby swampdog12345 » Mon Nov 03, 2014 7:09 pm
Thanks everyone for the info. Not sure I want to post my first chassis for the world to see, but I'll think about it.
swampdog12345
Re: Axle Question
Postby Gameover » Mon Nov 03, 2014 7:21 pm
I posted mine no worries here my friend we will all help you along the way. I used square tube for my axles less friction.
