can it be fixed?
can it be fixed?
Postby Dundee Denny » Thu Jan 16, 2014 8:44 pm
The Boyz are puzzled how to fix this.
Any ideas on how to straighten this out?
Thanks, Dundee Denny
Dundee Denny
Re: can it be fixed?
Postby Dundee Denny » Thu Jan 16, 2014 8:45 pm
Dundee Denny
Postby MoparGreg » Thu Jan 16, 2014 8:47 pm
Theres probably a few ways to fix it. I would probably heat it up with hot running water & try & push it back. Then brace the inside with some wire or a paperclip straightened out. If it snaps while bending, you will need to glue it back together & reinforce.
MoparGreg
Postby waaytoomuchintothis » Thu Jan 16, 2014 9:58 pm
That's what I would try first thing. Watch the areas where the plastic shows stress, the white areas, they will only bend so many times, then they will part, stressed on not.
Postby HomeRacingWorld » Thu Jan 16, 2014 10:47 pm
Be careful, make sure the boyz tap the keg AFTER the work ok?
And yeah, ditto that warm water advice.
Postby Wolseley Hornet » Fri Jan 17, 2014 9:45 am
Is the glazing insert a good enough fit to push the body on to it after heating up?
David.
Wolseley Hornet
Postby Dundee Denny » Fri Jan 17, 2014 4:08 pm
Great advice Harry, about not tapping the keg until after the attempted fix!!!
Appreciate all the advice, Saturday will be the big day to see what happens!!!!
Dundee Denny
Dundee Denny
