Home Racing World • View topic - Not your average slot car.............
Postby DRW21 » Fri Jan 15, 2016 5:18 am
DRW21
Re: Not your average slot car.............
Postby Audi1 » Fri Jan 15, 2016 5:41 am
Impressive all the way around! But, how does the differential work?
Postby DRW21 » Fri Jan 15, 2016 6:31 am
How ya doin' Allan?
Very well to be honest. It does run smooth in and out of corners.
I can set the wheels with the screws up and after going round just 1 corner they screws don't line up any more.
The diff makes the 4WD work so much better.
DRW21
Postby CJR » Fri Jan 15, 2016 7:00 am
:text-bravo: looking forward to more on this.
CJR
Postby ccobra » Fri Jan 15, 2016 7:41 am
Nice, I like that 2 pinion diff. I'd bet it would even work noticeably better in just the two wheel drive mode.
ccobra
Postby bill from nh » Fri Jan 15, 2016 7:57 am
Definitely one very interesting car, Dave. If you ever build another of those gear diffs, I'd like to see a "How-to" article posted here.:)
bill from nh
Postby TuscoTodd » Fri Jan 15, 2016 8:34 am
WOW! That is a very cool build! I like both the one off differential (I had looked at trying to retrofit something from the RC world a while back) and then tying it to independent front axles as well is pretty darn slick!
Thanks for sharing!
Postby chappy » Fri Jan 15, 2016 10:14 am
Very impressive design work.
I had to look for a bit to see how it all works and then noticed the second pinion.
Great process.
Postby Florida_Slotter » Fri Jan 15, 2016 10:27 am
I like it!
Doesn't it feel great to be working outside the normal boundaries?
I for one enjoy uncharted territory.
On my large list of things to do is to change the Flat-6 motor in my Slot.It Audi R-18 e-tron quattro to a Flat-6 RS, which is a 25,000 rpm motor with 240 grams/cm of torque. With the all wheel drive I'm hoping to get the car to come out of a corner hard, very hard.
Looking forward to hearing more about your project.
Postby GPCruisr » Fri Jan 15, 2016 10:28 am
GPCruisr
Postby DRW21 » Fri Jan 15, 2016 1:55 pm
DRW21
Postby CrockettNZ » Fri Jan 15, 2016 1:59 pm
Wow Dave that is impressive
I have thought of doing a diff in a rear wheel drive car but was not sure on how to go about it
A how to would be great
DC
CrockettNZ
Postby Beast Lee » Fri Jan 15, 2016 2:04 pm
Very nicely done... Wow...!!!
Beast Lee
Postby Retro Racer 44 » Fri Jan 15, 2016 5:32 pm
That is just awesome, and by the way, it will look perfect on a flared Escort.
Retro Racer 44
Postby walker » Sat Jan 16, 2016 4:10 am
What an excellent work...
May I summarize the working principle, to see if I understood it ?
Seen from rear :
- The left crown is simply screwed on the axle
- The right crown is fixed on the drive pulley and both are fixed on the hub
- This hub runs freely on the axle.
- The FAAS gear runs freely on the axle.
- There are three pinions installed.
If I am right, one final question - how did you fix the pinions in the gear ? Did you solder in their tiny shaft protrusions ? Or did you use the old trick with hammer and center punch ?
Roland
walker
