Home Racing World • View topic - Pre War Garage
Pre War Garage
Re: Pre War Garage
Postby dreinecke » Wed Nov 20, 2013 12:42 pm
Doh!
Re: Pre War Garage
Postby whitworthnut » Fri Nov 29, 2013 10:54 am
whitworthnut
Re: Pre War Garage
Postby Wolseley Hornet » Fri Nov 29, 2013 2:21 pm
The boys would be enthusiastic users of Brylcreem then, I guess?
David.
Wolseley Hornet
Re: Pre War Garage
Postby Ember » Fri Nov 29, 2013 7:40 pm
Re: Pre War Garage
Postby TsgtRet » Sat Nov 30, 2013 1:06 am
Dapper Dan!
That Bugatti is beautiful.
Re: Pre War Garage
Postby whitworthnut » Wed Jan 29, 2014 11:57 am
whitworthnut
Re: Pre War Garage
Postby RazorJon » Wed Jan 29, 2014 12:27 pm
Some fine work, details are perfect :text-bravo:
Re: Pre War Garage
Postby whitworthnut » Wed Jan 29, 2014 2:22 pm
Thanks Bibbster. You're absolutely correct. I've been using flat humbrol and it keeps coming out shiney. I'm mixing it well, but it just doesn't come out flat and some of it takes weeks to dry. It's really ticking me off. Using flat clear coat is a great suggestion which I will follow. Thank you. Constructive criticism is always appreciated as I am fairly new to this game.
whitworthnut
Re: Pre War Garage
Postby Ember » Wed Jan 29, 2014 2:32 pm
Some matte clear coats are better than others. If you want an enamel base it's difficult to go past the ModelMasters DullCote. But I use acrylic these days so it tends to be Tamiya TS80 matte clear for me.
I don't use model paints much any more, usually just artist acrylics from the tube. But Tamiya do a 'flat base' which can be added into the mix to further flatten their colours. I would expect to find something similar in the Humbrol range.
Re: Pre War Garage
Postby whitworthnut » Thu Feb 06, 2014 10:30 pm
whitworthnut
Re: Pre War Garage
Postby Ember » Thu Feb 06, 2014 10:39 pm
Love the stairs. Very appropriate.
Re: Pre War Garage
Postby whitworthnut » Thu Feb 06, 2014 11:12 pm
There is a profound tranquility about a vacant warehouse space and yet it seems to openly embrace the outside world.
The project seemed simple at the outset, but everything required a jig to construct in a plum and level fashion. I tried a really, really tiny spirit level, but I couldn't see the bubble. I attempted to dado the risers, but there simply wasn't enough material to work with. The stairs were aged with tea and a solution of oxidized steel wool and vinegar. Treads were individually scuffed for a wear pattern. Tomorrow I lay individual planks for the loft floor which is supported by a triple 2 X 10 beam and 2 X 10 joist 24" OC. Stair rails are piano wire - 1/16" I think.
whitworthnut
Re: Pre War Garage
Postby Wolseley Hornet » Fri Feb 07, 2014 10:05 am
I'm looking forward to the scale dust and cobwebs.
David.
Wolseley Hornet
Re: Pre War Garage
Postby Ember » Fri Feb 07, 2014 4:13 pm
I think the office needs to go up there.
Re: Pre War Garage
Postby TsgtRet » Fri Feb 07, 2014 4:34 pm
