Home Racing World • View topic - Zipper Top Proxy Builds
Re: Zipper Top Proxy Builds
Postby bkrownd » Mon May 27, 2013 3:27 pm
bkrownd
Postby bkrownd » Mon May 27, 2013 4:39 pm
bkrownd
Postby dreinecke » Mon May 27, 2013 5:45 pm
How about thinning the sides around the wheel wells and then a little stretching? Just have to be careful not to do too much. Don't use a Dremel, use an Xacto blade and scrape it away. I like to make pencil marks and use tape to keep me in the area I'm working in. That way I don't slip and take out our gouge something else.
Postby bkrownd » Mon May 27, 2013 5:57 pm
I'd rather cut up the chassis, which is less risky and cheaper to replace. This resin is a bit brittle, too. I'll have to thin the fenders a bit, naturally, but that won't be enough on its own.
bkrownd
Postby TsgtRet » Mon May 27, 2013 7:22 pm
Bkrownd, I have that same body in my "to be done" pile, I'm shooting to do a "what if" 1957 La Carrera car. Looks like it will make a very different zipper!
Postby dreinecke » Mon May 27, 2013 7:42 pm
Gotcha. Bummer!
Postby waaytoomuchintothis » Mon May 27, 2013 8:24 pm
Postby hoganracing » Tue May 28, 2013 12:01 pm
hoganracing
Frequent Flyer
Postby waaytoomuchintothis » Tue May 28, 2013 12:39 pm
Looking good so far! You can bend the roll bar from brass rodd pretty easily, and you can use a pencil to bend it over for uniform curves. There's no need to go crazy with a whole cage like I did. It really isn't right in my car anyway. In 1960, the Pettys more or less invented the full cage. Others just had a U shaped piece of pipe with lots of reinforcing and welds. Some also had back braces coming from the top corners to the rear floor. Good luck!
Postby HomeRacingWorld » Tue May 28, 2013 12:52 pm
Well, well, well, look at that. The great flyboy is building a race car :)
Detail Note* On this year Ford the were no flaps :)
Look good Patrick. Looking very good.
Postby Jesla » Tue May 28, 2013 1:16 pm
Flaps???…. you are talking about the Wing Windows, Right?
Jesla
Postby dreinecke » Tue May 28, 2013 8:03 pm
Well, none of these suck...great tip on the duct tape - I'll use that for sure!
Postby Derby City Speedway » Tue Jun 04, 2013 8:02 am
my newest addition :grin:
both chassis are a great fit wheelbase wise, with some frt/rear chassis trimming they fit just fine body wise.Zipper top is molded in, as is the headlight covers.
on carrera chassis
on monogram chassis
Derby City Speedway
Derby City King
Postby HomeRacingWorld » Tue Jun 04, 2013 8:21 am
My my my. THAT is a work of art.
Very cool man, very cool indeed.
Postby bkrownd » Tue Jun 04, 2013 8:43 am
What kind of material are people using for roll-cages? Modelling tube? Donor model kits? Lollipop sticks?
bkrownd
