1/32 scale Kurtis-Kraft Midget lives and runs! Video added!
Re: 1/32 scale Kurtis-Kraft Midget, carving has begun!
Postby FootScoot » Sun Dec 08, 2013 4:16 pm
I admire those who have the talent to do wood carving and it looks like a car. I wouldn't be very good at as I'm all thumbs when doing things like that. I can see it in my mind but getting it to look like what I'm thinking never happens. I guess I just lack that talent. :)
Postby RazorJon » Sun Dec 08, 2013 7:39 pm
get some cloth tape and cut it the width you want and build it up with tape, the texture of the tape will look like upholstery
Postby padirtfan » Mon Dec 09, 2013 6:57 am
That's looking really good! Some 1/43 scale running gear would probably work for that.
padirtfan
Postby Wolseley Hornet » Mon Dec 09, 2013 11:09 am
David, how about fabricating the grille,say by soldering brass or nickel silver strip.
You could then file it to shape, and when the body is nearly ready , glue it on before pouring the silicone.
This would make it easier to get all the sharp edges; easier than trying to carve them in balsa.
Or, maybe easier, make it up in plastic card strip.
Just a couple of ideas.
David.
Wolseley Hornet
Postby whitworthnut » Mon Dec 09, 2013 4:33 pm
Well done Dave. I like to see someone as driven as myself. Makes me feel normal. You also must have an understanding wife.
whitworthnut
Postby hoganracing » Mon Dec 09, 2013 10:11 pm
From where I am, it looks good, as does the entire car.
Patrick
hoganracing
Frequent Flyer
Postby Wolseley Hornet » Tue Dec 10, 2013 7:34 am
It looks magnificent,David!
Is it that a slim can motor won't fit under the driver's seat, or is it that it won't fit within the width of the body?
If it's the first, then a Carrera Go motor with an extended drive shaft might just fit under the bonnet(hood,sorry) because those motors are just shorter than the slim cans.
If it's the second,you might have to invoke a bit of "modeller's licence", and carve the body a bit wider than truly scale.
Better to find out now than when the first one comes out of the mould! :angry-banghead:
A chap on Slotforum did some Midgets for sale a few years ago. He used a modified Strombecker body, and a long slim can motor was a very tight fit.Were Strombecker Midgets 1/32, or 1/24.
David.
Wolseley Hornet
Postby ListerStormGT » Tue Dec 10, 2013 8:32 am
Great work David, really cool to see you got this done so quickly. :clap:
Postby DHansen » Tue Dec 10, 2013 9:55 am
There are some square H.O. motors that have plenty of power that would fit under the seat with room to spare. Check out Slot Car Express and look for pt# SCE-FB-1, Fyrebox-1 High pref. motor. Or even the Tecno Slot 1/43 scale chassis kit.
DHansen
Postby RazorJon » Tue Dec 10, 2013 10:32 am
what about those toothbrush motors :)
Postby Wolseley Hornet » Tue Dec 10, 2013 10:47 am
If that motor is fitted with its widest dimension across the car, you're going to be ok.
The final castings can be much thinner than the master, because they aren't going to need to take the rough handling of doing the initial modelling.
Why not do a quick slosh cast as thin as you dare - then you'll see how much room you've got.
David.
Wolseley Hornet
Postby ourwayband » Tue Dec 10, 2013 3:53 pm
Lookin' great!!!!
Postby padirtfan » Wed Dec 11, 2013 2:22 pm
Wow, that is really nice looking.
padirtfan
Postby Wolseley Hornet » Wed Dec 11, 2013 2:56 pm
Ouch ! (on both counts!)
It'll be all that grinding of the teeth during the delicate carving.
David.
Wolseley Hornet
Postby dreinecke » Wed Dec 11, 2013 9:09 pm
Looking good!!!
