Home Racing World • View topic - First brass chassis
First brass chassis
Re: First brass chassis
Postby dreinecke » Wed Sep 02, 2015 8:16 pm
Postby Alaskaracer » Wed Sep 02, 2015 9:30 pm
Great video, the body and chassis look great! Any idea on paint scheme?
Alaskaracer
Postby Florida_Slotter » Thu Sep 03, 2015 4:58 am
Doc,
Hopefully this is the first in a line of chassis that will be coming out of your shop. Each time you build, the chassis just come out a bit neater and with more and more little features that help it get around the track better and better.
Most of the tuning that Harry and the gang does provides "isolation" of movement from different parts of the car. Body lean and all those other little things just work. Can you get too much of this into a chassis? I certainly do think so.
Now, I found it quite interesting that with a hard body mounted on a chassis the body mount is quite critical. The pan or pans must be all fixed on a single plane. Quite interestingly the chassis that I received with my George Turner Models McLaren M1A has a very similar design to what I have stumbled upon. It is a "shaker" style plate that has just a tad (about .015) of movement in it. This seems to be work just fine.
If you take a look at the HRS-2 chassis, it is very similar in design. I do think that this provides the optimum in body / chassis isolation. Of course it is strictly my opinion.
Now on the subject of removing excess solder . . . . . . Dennis Samson, when asked what was the best way to remove excess solder by me a few years ago gave me the best advice possible. "Simply do not put any excess solder on!"
I have found that using .032 wire solder will let you make excellent joints and not bury the chassis in excess solder.
Keep up the great work.
Postby mattb » Thu Sep 03, 2015 5:45 am
Kind of hijacking this thread, but it seems appropriate. I have a roll of Stabrite solder I use. It is 1/8 inch or more. I see above a reccomendation to use .032. I've never thought of that. Maybe that is part of what I am doing to keep from having neat joints with minimal solder. What do you guys think? I use my iron for most work, but occaisionally I use a mini torch. The torch heats quick when I have a couple of big pieces of brass together.
As to chassis design, I am finding that in all my scratch build or even Dynamic chassis, a brass plate underneath makes the best handling package of all with a body mounted loosely.
Postby Florida_Slotter » Thu Sep 03, 2015 6:40 am
Matt,
I just put together some chassis discussion over in the Scratchbuilt section.
Hate to see a thread highjacked.
Come on over and let's talk there.
Thanks.
Postby dreinecke » Thu Sep 03, 2015 11:07 am
Postby RazorJon » Thu Sep 03, 2015 11:12 am
that will race, well done :text-bravo:
Postby Z-carfan » Thu Sep 03, 2015 11:19 am
Dreinecke, is the bracket a PM forged motor mount? Been trying to figure out what to use. I am guessing that the rear 'bearings' are a tube inside a tube setup?
