Home Racing World • View topic - Penelope Pitlane Clubman chassis with FF motor
Postby munter » Thu Oct 30, 2014 3:27 am
This is a small chassis designed for small saloons. It is intended that a FC motor type be used but I have put an FF motor in. If the motor uprights are left flat the FF motor sits down and meets the axle nicely. A motor plate needs to be made up first.
I have never used a PP chassis before but this runs smoothly and quietly. Next I need to sort out a suitable body.
Regards
munter
Re: Penelope Pitlane Clubman chassis with FF motor
Postby Dangermouse » Thu Oct 30, 2014 3:33 am
Nice idea
I usually start with the body and try to find a chassis - I might adopt your approach - set up the chassis and then find a body :)
Dangermouse
Postby btaylor » Thu Oct 30, 2014 4:02 am
Nice build! with that adjustability, any body should work great!
Postby HomeRacingWorld » Thu Oct 30, 2014 6:35 am
Never worked with this one, well done showing how you altered it. Smart thinking with that adapter.
Postby munter » Thu Oct 30, 2014 12:01 pm
munter
Postby Wolseley Hornet » Thu Oct 30, 2014 12:07 pm
Would this one fit in a Mini?
Looks as though it might.
David
Wolseley Hornet
Postby Ember » Thu Oct 30, 2014 3:24 pm
I know someone who does a nice resin Giulietta that could be suitable. ;)
Postby munter » Thu Oct 30, 2014 4:12 pm
munter
Postby munter » Thu Oct 30, 2014 7:04 pm
After looking at an airfix Mini body and the chassis i would say yes it could be made to fit.....if you could overcome some issues.
To my eye the main issues would be the rear "kick up flat" of the chassis would have to be taken off. The slot in the guide tongue would need filing back so the guide could retreat just a tad and the lock screw underneath would have to be very flat or removed if you used 13" rims and tires.ie the chassis parts would need to be soldered or glued together. Chassis width is no problem as there is another narrower line that the chassis could be folded to.
munter
Postby Nor Cal Mike » Sun Nov 02, 2014 10:08 am
Munter, I am curious as to how wide the chassis is at the front and rear bushing uprights? I have a whole series of small saloon roadster bodies here looking for a proper chassis. I want to keep the tires inside the stock fender openings on these cars. Hence my interest in width.
Nor Cal Mike
Postby munter » Sun Nov 02, 2014 1:00 pm
Width at that point is 22mm or .86"
The chassis' come flat and you can choose width by folding on certain pre made grooves. I could fold one more time along the bushing upright line.
Steve Ward at PenelopePitlane is a helpful guy and will ship worldwide.
munter
