by dr fabio » Thu Apr 24, 2014 3:30 am
Are you running mags or no mags? For no mags...
Do you want it to look pretty or go faster? Buff down the front tyres by about 1.5mm in diameter. this will drop the front end and the guide will be fully in the slot. It rides too high but this was deliberate on jules part. Increase the front track so that the tyres are level with the fenders. Thats about a 4-5mm wider track at the front. The rear fenders can be lipped if you are really good with a soldering iron. This means you can increase the rear track about 4mm. Run the 13T pinion, no iff no butts. Grind bottom of interior flat to allow float. Grind all the way around chassis for float. Place about 5-7g of lead weight in front of motor. Or cut out motor cooling slat on the chassis. Place square of lead there. urethane tyres on the back. Lose weight from body anywhere you can!!
cheers
dr fabio
