Home Racing World • View topic - Newbie to try to make routed track...
Plastic Or Wood
All Things Track Building!
Postby bobbyraz49 » Mon Apr 07, 2014 2:50 pm
Hello ...
Is this what I want/need to rout on 1/2 MDF .....1/32 scale ? How deep ?
http://www.homedepot.com/p/Diablo-1-8-i ... /100660668
Thoughts/advice are welcomed !(AND encouraged) !! LOL
As always.....Thanks from Bob in Buffalo
bobbyraz49
Re: Newbie to try to make routed track...
Postby DixonJohn » Mon Apr 07, 2014 3:31 pm
Yes, that bit will work. Set it as deep as it will go. Can't tell from the pic if its single or double fluted. If it's double(Two cutter blades) Take your time with it. The double flutes make a great cut, they just tend to be a bit weak and will snap the cutter off if you get to much pressure on them
DixonJohn
"The Mayor"
Postby bobbyraz49 » Mon Apr 07, 2014 4:00 pm
^^^ Thanks Johnny and John !!!
The folks here are great !!
But ....slot car racing isn't a hobby....it's a FREAKING addiction !
bobbyraz49
Postby SRQSloter » Mon Apr 07, 2014 5:40 pm
Right here is the one you want. Double fluted. And you want to go about 9/32" deep.
http://www.slotcarcorner.com/Track-Brai ... t-p36.html
SRQSloter
Postby bobbyraz49 » Tue Apr 08, 2014 7:27 am
bobbyraz49
Postby woodman » Fri Apr 11, 2014 6:50 am
I wonder how these would work...Bits for CNC routers still have a 1/4'' shank..
It's a thought...
http://sharptech-inc.com/double-flute-s ... cut-spiral
Series 57-200 Double Flute - Solid Carbide Upcut Spiral Wood Rout
52-040 1/8" 1/2" 1/4" 2" US$21.96
woodman
Postby woodman » Fri Apr 11, 2014 7:09 am
After routing the grandsons track and all 5 panes of the mod. track my double fluted straight flute bit is done....
I think I'l go with the double fluted spiral bit next time..it pulls the material out of the cut...
The CNC guys will use these....
http://bitsbits.com/index.php?main_page ... cts_id=543Image
woodman
Postby bobbyraz49 » Fri Apr 11, 2014 7:16 am
Yesterday I ordered 2 bits from Slot Car Corner.
bobbyraz49
Postby masmojo » Mon Oct 20, 2014 1:00 pm
I have had others report that the spiral upcut bit produces a lot of tearout!???
masmojo
Postby bobbyraz49 » Mon Oct 20, 2014 6:58 pm
The 2 bits that I bought from Slot Car Corner were FANTASTIC !!! Worth EVERY penny.
I only required one,but perhaps another track is in my future.
bobbyraz49
