WHEEL INSERTS
WHEEL INSERTS
Postby TYMAG » Fri Oct 05, 2012 1:05 pm
O.K., They say the only stupid question is the one not asked. I am using the daytona wheels and tires, but wheels seem to small to accept inserts everyone seems to be using . Can some one educate me about wheel inserts? thanks :(
TYMAG
Re: WHEEL INSERTS
Postby TYMAG » Fri Oct 05, 2012 2:14 pm
Sorry, Daytona Pro-Tracks. Inserts in photos I see don't appear cut down that's what had me confused. Thanks for your response.
TYMAG
Re: WHEEL INSERTS
Postby TYMAG » Fri Oct 05, 2012 2:25 pm
I would prefer to use model kit wheels.
TYMAG
Re: WHEEL INSERTS
Postby TYMAG » Fri Oct 05, 2012 2:30 pm
Thanks much!
TYMAG
Re: WHEEL INSERTS
Postby waaytoomuchintothis » Fri Oct 05, 2012 3:36 pm
Another thing to look for, TYMAG... The difference between 1/24 and 1/25 model kits wheels is often the difference between fitting in the wheels with a little work, and fitting right from the box.
Re: WHEEL INSERTS
Postby Beach Oval » Fri Oct 05, 2012 4:13 pm
If I'm not mistaking, if your using the 1" and smaller PRO TRACK Wheels and Tires, the inserts from the kits are to large. I use the 27mm PRO TRACKS and true them down to 1". The 27mm Tires and will handle the inserts. If they are a little loose, I take 3M Blue Painters Masking Tape and put what I need onto the Inserts until I have a snug fit going into the rim. They pop out easy enough by just pushing through the rim with an Axle.
Beach Oval
Re: WHEEL INSERTS
Postby waaytoomuchintothis » Fri Oct 05, 2012 5:03 pm
Good idea. I sometimes have trouble when an insert is just a little to small and this method with the tape makes it equal all around.
Re: WHEEL INSERTS
Postby TYMAG » Mon Oct 08, 2012 11:56 am
Thanks Andy. You hit my problem dead on. I am using the smaller wheels.
TYMAG
Re: WHEEL INSERTS
Postby randy47 » Mon Oct 08, 2012 4:59 pm
Hi tymag, and welcome to hrw. I use rubber glue to put in the wheel inserts. Just take an old model paint brush and put on genorous amounts around the inside of the wheel on the outer edge and insert wheel. When you take it apart you just rub your finger on the old glue and it just rolls up and done. What type of wheel inserts are you using? What I mean is what kind of cars are you modeling on the slot car chassis? Randy
randy47
Re: WHEEL INSERTS
Postby TYMAG » Tue Oct 09, 2012 5:50 am
Building street stock type cars. Ford fairlane, Chevelle. Never used inserts, but, would like to start using wheels from kits, stock or reversed type. Also vintage modifieds. Wheel/tire combo I have been using too small to fit wheel inserts.
TYMAG
Re: WHEEL INSERTS
Postby Beach Oval » Tue Oct 09, 2012 7:32 am
TYMAG, I use the PRO TRACK 27mm Wheels, I true them down to 1".
Beach Oval
