Home Racing World • View topic - At last - it´s ready and done...
Re: At last - it´s ready and done...
Postby LloydL » Thu May 30, 2013 4:25 pm
It looks like you are going to be very busy Roland!
Regards, Lloyd
LloydL
Postby Cjent » Thu May 30, 2013 5:53 pm
Looks like a really great layout, Roland!
Cjent
Postby mgs75thmeu » Thu May 30, 2013 6:25 pm
Is it done yet? LOL
mgs75thmeu
Postby dreinecke » Thu May 30, 2013 6:48 pm
THAT is a great looking design! Can't wait to see it!
Postby racer6583 » Thu May 30, 2013 9:57 pm
that is going to be a tricky track to run, in either class looks like it will be a lot of fun to run on it.
racer6583
Postby masmojo » Fri May 31, 2013 8:13 am
SWEET!
masmojo
Postby pfuetze » Sun Jun 02, 2013 6:35 am
i really like that tri-oval design, Roland!
if you´re using the lexan strip for guiding the router, don´t ignore the possibilities it gives you. What i´m trying to say, don´t do the curves like you have drawn them. Nail the first one down and than use the flex of the lexan to get the radius - don´t switch from straigth to the radius directly, use the lexan to do some "curve entry" section. otherwise you could use a simple radius arm.
what i would change is the part of the track where the 2 small kinks are - use the lexan again to have a more flowing line there - that´s at least what i would do.
looking forward to more progress,
cheers,
Peter
Postby Broman62 » Sun Jun 02, 2013 5:36 pm
Postby Datto » Sun Jun 02, 2013 6:20 pm
BRoman, a meter is just a frog-hair over a yard if that helps. What a fantastic track plan! looking forward to seeing more!
Datto
